Question about Goodman Heating & Cooling
I changed the air filter in my Goodman Heat/Cool unit and now the air conditioner won't turn on.
    President:
  • 1,515 Answers
Hi, check to see if you have a panel kill switch on the indoor unit. If the filter was inside the unit, and you removed the panel, if the door panel is not on just right, it will not close this power switch so the unit will not run. Check it out, I am sure this is your problem.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Please rate this post, :))
Posted on Nov 03, 2010
  • 3 more comments
  • wendy_d_wayl Nov 03, 2010
    Thank you, that is certainly a good suggestion, however we tried that last night and even with the kill switch manually depressed, the interior fan/blower comes on, but the A/C unit outside will not turn on. This was the solution a year ago when I had the same problem, but not able to resolve it this time. We checked all the breakers, etc. Nothing.
  • Robert Horton
    Robert Horton Nov 04, 2010
    Hi, if you are sure you have power to the outdoor unit, you may have a time delay relay that has gone out, This will stop the contactor from energizing on a call from cooling, It is a small circuit board that is wired with the stat wires, and will lock the unit out. I by pass them to get it to run. Without being on site, I couldn't walk you through this as I would have to see the schematics to do this. Since the indoor unit is coming on, the problem is in the secondary, or 24 volt side not closing the contactor. If you are inclined to do so, remove the control panel at the outdoor unit. The contactor has either 1 or 2 sets of points on it, you will see where your main hot wires come into it and connect. To see if it will run, push the top part of the contactor down with a finger to close the points to see if it will start. If it does not start, its either the time delay board, or no low voltage to close the contactor on its own. If the blower comes on, it will take a few minutes for the outdoor unit to fire up as the stat will also have a delay, along with the one outdoors. Its hard to believe the time delay failed just because of a filter change, but has happened. Try to make sure you have 24 volts at the Red and yellow wires outdoors in cooling, and high voltage getting to the contactor across the 2 hot wires. You will need to get a inexpensive a/c meter to do these checks, its the only way to know. Please keep me posted on your progress.
    Shastalaker7
  • wendy_d_wayl Nov 04, 2010
    You are correct, it was lack of power to the outside unit. My older son who happened to be home (active duty military officer) replaced the fuses in the outside fuse box and fixed it. He showed me how to do it and left me extra fuses. Thank you for your help!
  • Robert Horton
    Robert Horton Nov 09, 2010
    You are very welcome.
    Shastalaker7
  • Robert Horton
    Could you please rate me on this post so I may get credit for helping you?
    Shastalaker7, Thank You.
What is wrong with my Goodman AC unit?
Sounds like it has no power getting to it at all. Dont forget that some circuit breakers have UP as ON and some have DOWN as ON. Do not just assume a common way is always the same. You may even have to have one UP and the other DOWN as on. Check what the switch or circuit breaker has written on it to be sure.
AIR CONDITIONERS run like a refrigerator, they manufacture their own Heat or Cool and blow air past the unit to give hot or cold air to cool or heat the Room. These do not require flowing water.
Sometimes people (wrongly) call EVAPORATIVE COOLERS air conditioners. (An evaporative cooler just blows AIR past flowing water to humidify the flowing air and therefore "cool" the area)
An evaporative cooler therefore would require running water and without flowing water, the unit may not start due to the installation of a "fail safe" switch. An evaporative cooler would generally have a large box mounted on your roof with open sides with filters which are kept moist by the running water and through which the fresh air is sucked and pumped into your home.
There are varying thoughts on both, I personally consider the REFRIGERATED style as the most effective type, but they are more expensive to install and run.
May 29, 2014 | Goodman Manufacturing GSZ130181A - 1.5 Ton...
Goodman pgb036075-1A heat pump
Check your filter if u havent, most heat units have some sort of safety interlock should inlet air flow be restricted or blocked. If not could be ignition components or board issues. Over 8 major items will cause "No Heat" issues if it malfunctions, a few costly, so you'll want to be through tracing out your circuits & safety loops.. Or Call a Pro......
Oct 20, 2013 | Heating & Cooling
Filter dirty and blowing warm air
If your filter is dirty,the fan inside the house cannot push the cold air thru the evaporator, cool air cannot circulate, this will cause the compressor outside to over heat and even damage it and possible trip some fuses or circuit breakers, with these hotter days you want to change out your filters more often, changing out your filters more often will keep the evaporator cleaner and allow the cool air to flow, easier.good luck!
Aug 08, 2011 | Goodman CLJ36AR42 Air Conditioner
Central air only blows a small amount of cool air out the vents. After running 12 hours it only cooled my small 1BR apartment 3 degrees. The filter has not been replaced since October 2009 but I can't seem...
I have a Goodman A/C unit APRF036-00B1. The out side unit seems to be sucking and bowing air, the coil is cool to the the touch and the blower seems to be turning. I've check what seems to be the obvious. A small amount of air is only coming out. Any suggestions?
Feb 21, 2011 | Goodman CKL36AR36 Air Conditioner
We gave a Goodmn Hertz 60 Phase I heat pump - installed this summer....worked great for cooling..now that temps are dropping we are needing heat. When we turn it on it comes on but never heats. Think it...
If you changed the unit but didn't change the thermostat it is possible that the thermostat that you have will not work with that unit. I see that the unit you installed is a heat pump, you may have a straight cool T-Stat. If you put the T-Stat in the "Auto" "Heat" mode the outdoor fan and the compressor should be workng as well as the blower fan. If it turns out that the outdoor fan and compressor are not running you will want to buy a Thernostat that is compatable with heatpumps should be 2 heat/ 1 cool
Nov 05, 2010 | Goodman PHKJ048-1 Air Conditioner
GSC130241AE Goodman Air conditioner does not restart
It could be a bad thermostat.When the unit isnt working does the tubing frostup? If you have heavy frost in the evaporator this could mean a leak or a dirty coil. Also make sure the filter is clean.
Jul 29, 2009 | Goodman CKL60AR60 Air Conditioner
Unit blowing cool air and runing all the time dont shut off
Bad blower relay, goodman has a sequential delay blower relay
Jan 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Goodman ac / heat pump
I just had a new unit installed and I am surfing for troubleshooting tips too. My unit is doing the same... cools well heat sucks. my problem has been isolated down to the reversing valve... It is constantly energised which means it is constantly in a/c mode even when kicking on the heat strips... We disconnected a line at the thermostat and it is working well as a heater now. You may want to check yours to see if it is actually kicking over into to heat mode... -rob
Nov 25, 2007 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
