Question about HP OfficeJet 7310 All-In-One InkJet Printer
Tray selection Is there any way to assign the lower tray as the default 8-1/2 x 11 paper feeder? I have envelopes in the upper tray as the lower will not adjust narrow enough to accept them. When I print the upper tray is automatically selected and I waste a lot of envelopes.
  • HP Master
  • 2,794 Answers
If there is such a thing for that printer it would be in the advanced settings under you printer driver.
Select control panel.
Select printers.
Move the mouse over to the printer.
Press the right mouse button.
Select properties.
Press the printing preferences button
Look under the advanced tab for the settings.
You could see if there is an updated driver on HP.com if that feature isn't listed.
Posted on Jun 13, 2008
I'm having trouble addressing an large envelope the printer wants to print from the upper photograph tray and not accept the envelope from the lower tray. I have the MX922 printer.
The upper tray on my 6120 has adjustable guides on either side of the document and can be set from 2" to 8.75" wide. It is not intended just for photos! I use it for ALL envelopes that will fit. I use the MS WORD "Mailings", "Envelopes", "Options", "Envelope Size" menu to tell the printer what size the envelope will be (any size not listed in the standard list can be customized from the CUSTOM option at the bottom of the envelope list). Your word processor should have something similar. Running from the tray should be a straighter run and will actually place less distortion stress on the envelope.
Use a mailing label for anything larger than 8.75". You can download a program from Avery (and probably other label manufacturers) that really makes labels simple to produce. Labels should also be run from the rear tray if possible so they won't wrap around your rollers.
Happy Printing.
Feb 10, 2015 | Canon Pixma MX922
Is there a lever or switch that tells the printer to grab from the front tray?
On the machine panel, the "feeder" button selects paper source and media type to be used. This must match the media/paper size selected in your software.
MP - multi-purpose tray
T1 - the upper paper cassette
T2 - the optional lower paper cassette
Dec 03, 2009 | Brother HL 2060 Laser Printer
Dell 1700 only printing to envelope feeder
make sure that the manual feed tray is not set as default make sure you main tray is
Apr 30, 2009 | Dell 1700 Laser Printer
Can't print envelopes
you need to select tray #1, manual feed.
tray #2 is auto feed- 8x11 sheet paper.
Jan 29, 2009 | Dell 3100cn Laser Printer
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
Letter size envelope does not fit into the paper holding tray
Hi cmwww920,
Usually letter envelopes are insert long-way into your printer. I recommend using the Microsoft Word envelope wizard to print Sender and/or Recipient addresses on envelopes. Here's how it works:
1) Launch Microsoft Word.
2) Click Tools > Letters and Mailings > Envelopes and Labels...
3) Type in what you want to see on the envelope.
4) The default feed direction is shown in the lower right corner of the dialog box. To change it, click Options and select the Printing Options tab. Adjust the settings as you please.
5) Click OK to exit the Options Dialog Box
6) Click Print (in the upper right corner of the "Envelopes and Labels" dialog box.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printing envelopes
If you look closely at the very front of the paper tray, just to the left of the sliding thing that keeps the paper from drifting out of the front, you will see a couple of illustrations showing how to position envelopes in the paper feeder. For regular letter-sized envelopes, or even greeting card envelopes, place them face down with the top of the envelope pointing to the left as you are facing the printer. The return address area should be away from you. Position the envelope all the way to the right side of the paper feeder, then gently slide the envelope all the way back until it is stops so that it is accessible by the paper feeder. Bear in mind that it will be flipped over when it comes out. To avoid wasting an envelope, do a trial print on a piece of paper to make sure you understand the positioning correctly. Good luck!
Apr 26, 2008 | HP Officejet 7210 All-In-One InkJet...
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
70 people viewed this question
Seeker5211
Seeker5211
