Question about Jensen's VM9312 Car DVD Player
How do i bypass the emergency brake wire on a dual xdvd700
I am hooking up a dual xdvd700 in dash dvd player in my 2001 dodge ram 1500. how do i bypass the emergency brake wire so i can play a dvd at anytime. Please describe the specifics of your problem below. We'll add
your post as a comment to 1badv6's how do i bypass the emergency brake wire on a dual xdvd700 problem, and notify you when a new solution is offered.
  • olen22 Dec 31, 2008
    i want to bypass the emergency brake to play all the time
Negative wire!!! Splice the brake wire,negative,and the car harness negative together.
Posted on Sep 09, 2012
All you need to do is connect the pink parking brake wire to a ground
Posted on Feb 19, 2009
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Posted on Jun 13, 2008
BYPASS THE KENWOOD DDX8017
Im guessing since this is an in dash dvd player your trying to bypass the emergency brake so it will work with the vehicle in drive. If this is the case all you have to do is take the wire that goes to the emergency brake and ground it somewhere.
Mar 04, 2013 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
I have a xdvd700 dual and want to bypass the brake thing but no remote is there anyother way?
Usually there is a handbrake connection that needs to be grounded to the chassis in order to bypass the screen lock. I normally wire it though a switch to ground and back to the handbrake, so if the car is inspected it works like it should.
Some units feature a footbrake wire that needs to be pulsed as well. This is harder to override. I use a bypass device from Peripheral called the PAC-TR7.
Dec 06, 2009 | Dual Electronics XDVD700 Car DVD Player
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Aug 26, 2008 | Dual XDVD8181 Car Video Player
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
Just ground out the Ebrake wire... it will work fine then. Even if you just link the ground and ebrake wire together and ground them together it works!
Dec 01, 2007 | JVC KD-AVX33 Car Video Player
Dual xdvd700 want to permanently bypass e-brake
1. Ground the E-Brake wire.
2. Insert a DVD
Let it play until you hear sound
Press STOP twice on remote
Enter 26604
Press ENTER
Oct 27, 2007 | Jensen VM9510 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
1,194 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
