Question about HP Photosmart C4580 All-in-One InkJet Printer
When I try to send something to print is says "printer paused" for no reason.
    Genius:
  • HP Expert
  • 1,325 Answers
Hello
reinstall the drivers .. go to this link and download latest drivers, by selecting your OS.
i am sure a clean reinstall will hinder any issue you are experiencing
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3418707&lc=en&cc=ca&dlc=en&lc=en&lang=en&cc=ca&submit=GO
Posted on Nov 03, 2010
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Problem whit printing
open printer folder from control panel double click printer then uncheck pause printing
Jul 22, 2013 | Office Equipment & Supplies
Printing page going to pause mode
check paper size setting and also auto paper size setting
Jul 28, 2012 | Ricoh Aficio 2232C Color Copier
Hp 6500a takes forever to print 1 page
Make sure that the right printer driver is installed.
Jun 04, 2012 | HP Officejet 6500 Wireless All-in-One...
Print jobs are completed with no problems sometimes, other times the print queue shows the job being printed, but nothing happens. Printer status shows "offline", but if I click on the...
Reason behind "offline" is communication between printer & system got interrupted,check weather printer is restarting it self ? check with another USB cable,check firm ware if low version up load it, check printer USB port on formatter is it dry solder? if no check the voltage in connector 17, between pin 1 & 20 is it 5V? if not check power supply connector J201 pin1, is it 5V? if not replace Power supply PCA.
If 5V showing between pin 1& 20 replace formatter.
Sep 09, 2011 | HP LaserJet 3050 All-In-One Printer
After each print the pause button will continue to blink and will not print another label. I have to manually open the print head, close it and press pause for it to print. I do not understand the...
The ribbon is the transfer rolls same thing.
But check if you have not activate the pause mode in your driver!
This is an option to have the printer pause after printing
Aug 04, 2011 | Zebra Z4M Printer
Hello, and thanks for any help you can provide. My Canon ImageRunner C5180 sometimes hangs on "Waiting to Print ..." That is, someone sends a print job, "Waiting to print..." begins to...
i think that the problem with hanging hides in your PC network and incompatibility of some files with printer driver version or something like this. Try to find from which PC do you have problems and look for software reasons. This machine is to big to make little problems...
Can you COPY when the machine trys to print? If you can, I think that everything with CANON is OK.
If you type the IP address of Canon in some of your internet browsers you will get instant access to WEB MONITOR and there must be error log somewhere.
Good luck
pifonski
Mar 02, 2011 | Canon imageRUNNER C5180 Color Copier
I have downloaded the driver and it all says it's good to go, but when I hit "print" it sends it to the printer and it says "Printer ready" but the status says "stopped" and...
make sure when you hit print and the dialog box comes up...make sure that the PRINTER is highlighted not the fax, scanner,copier or office etc...I had the same problem when I first got mine.. its a great machine also check that the printer is set as your default printer.. youll see a check and default next to the printer name in the printers folder.. and make sure your not all jammed up with pages to print open the printer folder (usuall in your startup in the bottom ri side where your start up items go.. if you have any questions email me back good luck
PS worst u have to do is delete the entire printer/fax etc set up and run the disc again. peace out
Feb 03, 2011 | HP J3680 Officejet All In One Printer
Was printing fine but now when I send something to print, the printer doesn't respond at all and just shows the "ready" screen
Is it connected directly to your PC, or is it networked?
In your printer dialog box, does the printer say "ready"? it may be "Paused" or "offline". Right click and select "resume Printing", and/or "use printer online"
Are you sure the cable is still connected and working?
try removing and reinstalling driver.
Mar 11, 2009 | HP LaserJet 3600n Printer
HP Photosmart C4580 All-in-One InkJet Printer Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
