I have 17" LCD viewsonic
    President:
  • 2,678 Answers
Yes you can if you can source one however it may be more cost effective to replace the monitor.
Posted on Nov 03, 2010
Toshiba satilite C6550 has rainbow lines on half my screen the other half is fine ?
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the rainbow lines, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same rainbow lines it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | Computers & Internet
Toshiba lap top half screen rainbow lines
May 18, 2012 | Toshiba Satellite M35X-S149 Notebook
Out of range box on my screen
Your PC video resoliton is set too high for the monitor to display, it shoulde be set to the native resoltion of this monitor: 1280 x 1024 @60Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.viewsonic.com.au/product_pdfs/lcd/17/E-VA720-10142003.pdf
Unless the monitor has the problem inside:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Oct 10, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
My LG monitor displays rainbow color at the bottom half of the screen. how do i fix this? what part should i replace?
That is bad T-CON board which is part of the LCD panel assembly, not much you can do. You can try seating the connector on the T-CON board to see if it will solve the problem.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Sep 06, 2010 | LG FLATRON L1717S 17" LCD Monitor
ViewSonic monitor VS10780
i turn on after 30 sec turn off that happen all the time
Feb 19, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
The Right Half of My Screen Is Grayed Out
It seems unlikely that two pins would be missing. They would more likely be bent down. If there's no bent pins, it looks like it could be a faulty monitor. Certainly, when TFT displays go, they tend to manifest the fault in a colourless or multicoloured bar consistently across a portion of the screen.
Feb 04, 2008 | ViewSonic VA721 17" LCD Monitor
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Computers & Internet Logo
246 people viewed this question
David Payne
David Payne
