Question about Garden
Need to know how to replace oil in my honda hru173pu.lawn mower cant fid oil drain plug
  • 297 Answers
On these mowers you need to use a vaccum oil extractor or just turn the mower on its side and collect the oil right out of the dipstick tube. Try to do this with the fuel at a low level and the fuel cap tight.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 03, 2010
My Honda hru173pu mower blows white smoke and there's oil on the plug I haven't overfilled the oil do u think I need new engine rings
That is definitely a sign of bad rings. Sometimes people turn the mower on its side, the wrong side and then oil slips past into the cyclinder . Spray some carburetor cleaner into the plug hole then reinstall the plug. Start the unit up and see if it burns the oil from the cyclinder, give it a few minutes. If the problem goes longer than a few minutes then yes, bad rings.
Oct 08, 2015 | Honda Garden
How to change the oil in my MTD 6.5h Honda yardman
Many mower engines no longer have a drain plug, or the plug is covered by the deck or other components, the best way is to suck the oil out via the oil filler, there are plenty of inexpensive vacume pumps availble that makes the job easy, check out the dealers or e bay.
Mar 14, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I need to change oil in my yard man lawn mower. Where is the drain plug? I need to change the oil
Hi, you drain it out of the dipstick filler hole by tipping the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
May 17, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
How to change oil In a craftsman lawn mower, that has a honda engine. Misplaced my manual. Have decided to change my own oil rather than have it serviced every year I was doing a number of lawns so I had...
Look for a drain plug under the deck in the bottom of the engine (under the deck) known as the crankcase housing. Drain plugs come in different forms, but you will know it when you see it. IF there is no plug on the engine bottom, then check for a small plug on the side of the engine (above the deck) with a square head. That would be removed and the mower tilted that way to drain the oil. If no plug on the side of the engine then the oil will have to be drained out the oil filler tube. Remove the dipstick and tilt the mower that way to drain the oil.
May 15, 2011 | Craftsman Garden
Have a Honda HRU173PU lawn mower recently serviced by a dealer; new plug etc but slow to start and when under the pump cutting semi long grass it starts to backfire and the it dies.
Why you are not on the horn with the dealer, demanding that this thing be fixed is beyond any answer that I can give you! I think you know what to do or do you?????
Nov 18, 2010 | Honda Garden
My yard man mower is blowing black smoke when I crank it. Why would this be?? It was low on oil, but we filled it up and it still smokes. Do we need to change the oil? If so how? It has a honda engine, and...
Like the other guy says drain the oil out. Disconnect the spark plug wire (for safety). Place the mower onto a stable platform to work from. To remove the drain plug usually you need a 3/8 ratchet and I use a short extension so I don't skin my knuckles. Put the extension end into the drain plug and remove. Have a drain pan to catch the used oil. Clean the area around drain plug first. When oil is drained replace the drain plug and tighten. Add your new oil. ONLY ADD ABOUT 15 OUNCES. Use SAE 30 motor oil. Once you get the oil in set it on a flat surface and check for the proper level. Add if needed. Usually the push mowers only use about 16 ounces. I start with 15 because it is easier to add than remove the oil. Replace the spark plug wire, prime and start. It may smoke awhile to get the old oil burnt up.
Aug 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Need to know how to change the oil in my Honda w/Troy Bilt motor 11A-542q711 w/overhead cam GCV 160.
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Jun 06, 2009 | Garden
Does the 917 376150 have a oil drain plug? I want to drain the oil out without turning the lawn mower upside down.
well if you cant find the plug i suggest getting a cheap hand pump and just **** the oil out of the dipstick, sometimes there is no drain plug.
May 01, 2009 | Garden
Oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
Apr 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Garden Logo
144 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
