Question about Frigidaire Kitchen Ranges
I hit the cooktop too hard. A flash appeared under the cooktop. The entire digital diplay, stove, and oven quit working immediately.
  • Anonymous Mar 29, 2014
    entire cooktop and oven stopped working - lights on
  • 426 Answers
Sounds like a blown fuse or shorted wire replace and you should be back to normal
Posted on Jun 13, 2008
How to turn oven on on a Kelvinator Cookarama Oven (Older model)?
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
Jun 02, 2014 | Kelvinator Refrigerators
Oven door is locked
try unplugging it for a few minutes then plug back in
Mar 28, 2014 | Maytag Stove / Oven / Range Cooktop -...
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Frigidaire stove oven want come on model # FGF368GSJ
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Nov 06, 2012 | Frigidaire Stove/Oven/Range Cooktop -...
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Code S ab on screen
try pressing and holding the clock tab on the erc for 5 secs
this will usually cause the sab to flash 3-4 times and then retrun to normal operation mode
Oct 17, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Oven fuse blows - Nothing works
try lifting the stove top assy and checking wires under main top, leading to the elements them selves??? if tis tripping and not allowing to reset its gotta be an obvious short. isit hard wired directly to stove or into a 220 cord and plug???id look again, perhaps remove entire back panel and have someone trip on the breaker you might see where it flashes as it trips off
Apr 03, 2008 | Tappan TEF242 Electric Kitchen Range
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Ranges Logo
80 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
