Question about Acer Computers & Internet
The sound from the speakers are very muffled and echo, the sound isn't right
    Scholar:
  • 141 Answers
Hi karakayak;
you may try the speakers on another pc. You might have a defective speakers or a defective sound card, doing so will isolate the problem.
thanks
Posted on Jun 13, 2008
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
My problem is that the sound coming out of the speakers is muffled how can I fix it so the sound isn't muffled?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
(((the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer)))
hope this helps you
Aug 17, 2011 | Computers & Internet
Sounds sound like an echo chamber
1. Click Start, click Control Panel, click Hardware and Sound, and then click Sound.
2. In the Sound window right-click your Speakers and select Configure Speakers.
3. Follow the on-screen setup, and Test the available configurations.
4. Indentify whether or not one configuration appears to have less of an “echo” than others.
5. If the issue is resolved by modifying the configuration then you do not need to do anything further
May 18, 2010 | E-Machines eMachines Desktop PC
Rear speakers do not sound right they are working but sound muffled or something help??
Rear speakers in 5.1 are no more than sound reinforcement. The brunt of the work is done by the front left and right with most of the burden falling on the center channel.
Feb 11, 2010 | JVC RX-552V Receiver
All sounds on my computer sound like they're in an echo chamber
I had this problem. I right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' (realtek in my case) then clicked properties in the lower right of the open window, clicked on the enhancements tab, and found that my sound effect properties had been changed to auditorium. I clicked the selection arrow and changed the enhancements to 'none'. Oh happy day! No more echo.
Dec 14, 2008 | JBL CREATURE II Computer Speakers
I pluged in my speakers but the sounds are very low and wierd
you cant get echo on a specker there not made for that just normal sound
Nov 16, 2008 | Ozaki DT-500 3-Piece Speaker System...
My tv speakers are muffled
The speakers sound all good because you said "the speakers" are muffled .....it sounds like a problem on the board.....a capacitor a resister but its fixable....unfortunately only by a repairman
Sep 03, 2007 | Sony SPEAKER UNIT Computer Speakers
Speaker jack not working
Sounds like your right front output transistors/IC may have a problem, not the jacks. Time for a trip to the shop I fear.
Jan 13, 2007 | Onkyo TX-SR502 Receiver
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
