Question about HP Mini 1000 Netbook
Family member took it to dominican, plugged in started and closed a redirect window. computer went black , no power light or anything. here at home no different. no signs of life
  • HP Master
  • 2,404 Answers
Unplug the battery and hook up the AC Adapter. If you still don't get any power then go ahead and try another known working AC Adapter. If th
Posted on Nov 03, 2010
  • Ben Wabnick
    Ben Wabnick Nov 03, 2010
    that doesn't get the laptop to work, then that means the motherboard is
    bad. If the laptop turns on then that means you need to replace the AC
    Adapter.
How to restore factory setting on gateway model mt6705
Step 1:
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate. Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files. It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen Click the "Start" icon in the lower-left corner of your Windows 7 home screen. Click "All Programs" in the Start menu, then click "Gateway". Click "Gateway Recovery Management" to open the Gateway Recovery Management program. Click the "Restore" header, then click "Restore System To Factory Default". Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes". Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart. When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes. Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer. Your computer will reboot. After the computer restarts you will need to configure Windows 7 with your personal preferences. b> Recover at Startup Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program. Click "Restore System From Factory Default". Click "Next" to begin the restoration process. The process could take anywhere between 30 and 90 minutes.
Feb 25, 2013 | Gateway MT6705 Notebook
GATEWAY WINDOWS 7 FACTORY
Feb 15, 2013 | Gateway LT2021u Netbook
03 Trailblazer Power Loss and Brake warning and ABS lights appear
You need the system scanned with a special tool to see what faults are present in memory
Mar 01, 2017 | 2003 Chevrolet TrailBlazer
Shut down, black screen
It may be. Were you enabled hybernation for closing lid, this situation wouldn't have arises. You closed the while on means heat transmission may have caused this situation.
Apr 13, 2017 | Dell XPS M1530 Laptop
I took my ps3 over to family member house , no RCA jacks. So we use HDMI. Now back home with game. Can't get game to play back with RCA jAcks
There could be several things wrong here. There may be a switch that toggles between HDMI and RCA or you might be pluging the wrong jacks into the wrong plugs.
Sep 09, 2011 | Sony Video Game Consoles & Games
Comp fail
Try to boot the computer with your windows installation disc. If it will boot off the disc, try to perform a start up repair. When you write back, give as much information as you can about the computer
Sep 06, 2009 | HP Pavilion dv9700t Notebook PC
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
My sync master 930 bf
Your CCFLs might be going bad. CCFL stands for Cold cathode fluorescent lamps. These are the lamps that provide backlight for the LCD Monitor. These lamps do not last forever, and are a very common part to go bad. The circuit that provides the power for the CCFL is called the inverter, it might be going bad, but I still think it is the CCFL. Only trained techs should try and replace a CCFL or fix an Inverter. CCFLs do contain mercury, but only small amounts.
You have a backlight issue. The backlight system is comprised of CCFL lamps and an inverter circuit board.
My advise, open up the back of the LCD and see if anything is not plugged in correctly. Maybe something got knocked loose.
Try and find the inverter board, does anything look bad on it.
If you are confused by now, don't panic, just get a new LCD, and sell the bad one on ebay. There are people who like to fix them. I have repaired a few backlight issues on LCD monitors and I do work on them professionally.
http://en.wikipedia.org/wiki/Cold_cathod...
Nov 14, 2007 | Samsung SyncMaster 930BF 19" LCD Monitor
Sceptre D50X black screen
If a monitor shows a normal screen at startup but goes bad after the Windows logo disappears, your Windows video setting is probably not compatible with the monitor. You can start Windows in safe mode to select a compatible resolution for your monitor.
Aug 16, 2006 | Sceptre Dragon Eye D50X (White) 15 in.CRT...
HP Mini 1000 Netbook Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
