Question about Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
Have a master 165,000 btu turbo heater it always starts and runs but sometimes it will run for 5 minutes 7 or 10 no matter where i set the built in thermostat,any tips ????
    Scholar:
  • 146 Answers
I would start by checking the fuel filter form the tank to the nozzle. If this is getting dirty the heater will slowly start loosing the red glow on the nose cone until the until shuts down.
Normally if it sets for a few minutes it will start and run again.
You can order a filter replacement kit that has all of your filters included.
Posted on Nov 03, 2010
The heater is not igniting when switched on
what model what type of heater
its ok to mention not working
but more info please on the fault
the maker model type issue
then we can find you more details and manuals etc...
Apr 25, 2015 | Rinnai Heating & Cooling
Reddy-Heater will start then run about 10 seconds then stop.
The heater has a photocell that has to see the correct flame or it will cause the heater to turn the unit off.
I would suggest checking the the pump pressure and the output filter to make sure you are getting the correct amount of pump pressure to the nozzle.
Here is a link to the actual service manual.
http://www.desaparts.com/hsi.html
Oct 08, 2012 | Reddy HEATER RH170T 165,000-BTU PORTABLE...
I have master torpedo multi fuel when its cold it work fine but when kick on after its hot it wont it just blows smoke out and have to unplug it
fuel pressure could too high you could have a cracked rubber hose on the pump sucking air start with fuel pressure and that will help us to get started
Dec 13, 2010 | Milwaukee Tool Master Heater 165,000 BTU...
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
My heater starts fine and runs maybe 5 minutes then shuts off. Any clue where I should start looking?
Here is a tip about troubleshooting Torpedo Heaters
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Jan 12, 2010 | Milwaukee Tool Master Heater B200 Series...
MY KEROSENE HEATER STARTS, RUNS MAYBE 5 MINUTES THEN SHUTS OFF
Same problem I had and it was the CAD/flmae sensor. you can get one that will fit from Mr. Heater for 3 bucks or from reddypats.com for 18. the wires are a different color but all you do is clip them and splice them to your old wire harness. It does''nt matter how you hook them as there is no hot and ground just a complete circuit.
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater runs for 20 minutes then shuts off
These heaters have built in thermostats. Sometimes they are adjustable sometimes they are not, check to see if your is adjustable and see if this fixes your problem. Also check to see if there is any air restrictions possibly causing the heater to over heat.
Dec 03, 2008 | All-Pro Forced Air Kerosene Space Heater...
Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat Logo
988 people viewed this question
Top Master Heaters Heating & Cooling Experts
Gil Shultz
Superior Maintenance
Paul Carew
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
