Question about Ariens 42" Riding Lawn Mower Blade 03987000
The transmission on my ariens automatic 19 hp stopped working, what can i do to fix it?
    New Friend:
Is it possible to add gear oil to the gearbox? Mine was leaking for a while and now has stopped....I worry its got NO oil!
Posted on Jul 15, 2015
  • 297 Answers
Check the drive belt first, it will be the upper belt. you will need to make sure a stick or something hasnt jammed up there and knocked it off. It will be easier to remove the mower deck so that you can get under the tractor to look up and check it out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 03, 2010
Will not start right from the store. It has something to do with the seat switch.
Try shorting the seat switch then try cranking while seated on your mower.
Mar 06, 2015 | Ariens 42 in. 19 HP Kohler Hydrostatic...
I have aN ARIENS 42" a husqvarna mate. I found a wire off and not sure where it goes, it will not start
that might not have anything to do with your issue. there are plugs that aren't used...
does it crank and not start
or
not crank ???
Oct 20, 2014 | Ariens Riding Lawn Mower. 42 in. 19 HP...
What is a hydrostatic transmisson?
Hydrostatic transmissions are automatic "Hydraulic drive" transmissions. The largest producers of hydrostatic transmissions are Hydro-Gear, Tuff Torque and General Transmissions.
Jun 16, 2014 | Ariens 42" Riding Lawn Mower Blade ...
I have a 1994 bmw 325is automatic transmission and reverse wont work at all and drive is starting to slip ive never changed transmission oil. IF i change transmission oil and filter will it fix this p
hi friend,,,,,,,,,,if your transmission is ZF 5 HP 18 or 19 or 24 or any other type of ZF 5 or even 4 ,,,,means with 5 or 4 speed ,,,you have to remove the pan oil and check the DG clutch ... most probably the side of revers is broken ,,,,,in other word ,,,changing oil of your transmission is not helping you at all ,,,,,,,,if you give me further information so I can help you more and to tell you what is your exact problem..........just tell me the type of your transmission,,,,I can check it on my list but better is you say and not to make a mistake for better diagnosis,,,,,,,,,,thanks
Nov 29, 2013 | 1994 BMW 3 Series
I wish to install a manual choke since the automatic choke no longer works
Brent,
Most any auto parts store will have a manual choke conversion kit for about $10us.You will have to be a little creative to hook it up. But...your engine shouldn't need to be choked once it runs awhile and is still warm. I would look for other causes like binding linkages, unhooked springs and loose carburator mounting.
Nov 17, 2013 | Ariens Riding Lawn Mower. 42 in. 19 HP...
Transmissiom shifts hard from 2 to 3 and no overdrive
This stuff works GREAT! You can buy it at any local auto part store for about $12. I added it to my 2001 Sonata that was shifting had from 3 to 4 (on the highway). I copied this info from there website. Google it and you'll find tons of reviews, all of which are good.
What Is Lucas Transmission Fix?
Lucas Transmission Fix is a thermal stable blend of petroleum extracted additives. It contains no solvents or anything else that would be harmful to an automatic transmission. It contains a seal conditioner to help stop leaks around seals. It contains a polymetric film which is designed to stop worn bands from slipping. It allows the the transmission fluid to run cooler and controls foaming. It mixes with all automatic transmission fluids. It also contains lubricity agents for smooth, precise shifting. Lucas transmission fix extends existing transmission fluid life up to 3x.
What can Lucas Transmission Fix do for my vehicle?
  • Stops automatic transmission slip
  • Cleans and lubricates sticking valves for smoother shifting
  • Stops leakage around seals
  • Extends fluid life up to 3x
  • Extends the life of your transmission substantially
  • Protects your transmission under all severe service applications
How much Lucas Transmission Fix do I need?
One 24 ounce bottle is all you need. Lucas Transmission Fix will not fix a mechanically unsound transmission. If you have slipping and/or shifting issues this product will help.
Sep 29, 2010 | 2001 Hyundai Sonata
Need head gasket
part num 28938c assuming its a 5 hp HH50? i have 19 in stock at lakeviewpower.com
Nov 20, 2009 | Garden
Ariens 911502 trans cable.
Good news and bad news. Good news is that they do still make that part for your mower. Bad news is that it is a VERY costly little guy! Below is a website that is your exact part. Let me know if there is anything else I can do for you. I know this answer is probably a little late for you, but I am very new to this site. Hope this helps. Let me know how it goes. Thanks.
http://search.cartserver.com/search/search.cgi?keywords=01437100&cartid=a-8671&category=Ariens_Parts&maxhits=20
Jul 05, 2008 | Black & Decker 19" Electric Lawnhog...
Ariens 42" Riding Lawn Mower Blade  03987000 Logo
791 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
