Question about Samsung Televison & Video
Someone just gave us a samsung 1081i... we do not have a cable box but we have cable... can we use this tv without a box?
  • Samsung Master
  • 8,457 Answers
Yes,just setup ur tv up to recieve pay cable tv signal,not the tv free DTV air tv signal.U should be find.
Posted on Nov 03, 2010
How do i setup my tv through surround sound without a cable box?
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
Dec 27, 2013 | Samsung Televison & Video
On the Onkyo receiver, I have a uverse box hooked to an hdmi input, and a Samsung un55c8000 hooked to the hdmi out. Even though the uverse box is set to output 1081i, the Onkyo receiver tells the...
Hello, please press and hold the display button on the remote for 3 seconds to confirm the incoming resolution from the cable box. Thank you, Onkyo USA
Jun 04, 2017 | Onkyo TXNR708 72 Channels Receiver
Someone just gave me a Toshiba 27AF42 but the power cord has been severed from the wire. Do you have a replacement part for this? How can it be fixed? Thanks, Roseanne
if the cable is still connected to the TV without a plug simply buy a plug reconnect to the cable but make sure the cable is connected correctly to the plug and it should work
Oct 13, 2010 | Toshiba 27AF42 27" TV
Hi! i just purchased a Samsung SyncMaster P2370HD P2570HD flat screen tv and I was wondering if you are able to tell me the correct settings to put on the TV to get the best picture? The picture does not...
Hi Suzette my name is Roety,
I can help you with your issue ,
First of all make sure you have an HD signal connected.
These days using a non HD box will produce a bad picture on an HD TV.
If using a cable/Dish box set the output resolution to 1081i only,
for picture controls set them all center and max out the picture/contrast control
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 28, 2009 | Samsung Televison & Video
Hi Someone gave me this old Sanyo TV Model # 31C4760, When I connect it with my cable it catches only basic (13 channels) instead of 60 channels. How should I see all the channels? What should I do?
If it is very old (with rotory/manual channel changer), you are out of luck unless you get a cable box from your cable company - this will let you set your TV on channel 3 or 4 and the cable box will find all stations for you. The cable box goes between your wall cable and your TV.
It your TV has an electronic tuner with a remote, try going into the setup menu and select signal source as CATV instead of antenna.
Please rate me.
Nov 20, 2009 | Televison & Video
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Nov 04, 2009 | Samsung HT-X810T Theater System
Connecting HT/Cable box to TV?
Get a fiber optic (Toslink Optical) cable to plug into the TV's optical OUT between the red/white RCA audio and the spot where you plug in your cable TV, to the Optical IN on your HT-DS610. This way all audio coming in to your TV from any source goes directly to your hi-fi in all it's splendor.
Have fun!
Aug 28, 2009 | Samsung HP-S5053 Television
Changing resolution settings
Change the resolution through your Cable / Satellite box - Go into the menu. Most of the Akai tv sets do not have an option to change the resolution.
Mar 24, 2008 | Akai PT5598HD 55" Rear Projection...
Program satelite or cable
you are not specific as to programming cable or satellite .if you have cable tv with a cable box there is no need to program tv channels.the tv should be left on channel 3.check the back of the cable box & tv it may also be connected thru rca/s-video or componant cables meaning the tv should be on a line in/source ,or video input. for a tv without a cable box
you can do the auto or manual programming. no need to be on channel 3. if you have satelllite tv you need the box to hook up to your tv.you cannot bypass this box unlike cable tv.also check the back of the box for the other possible connections
good luck
wg
Jan 28, 2008 | JVC AV-27D202 27" TV
Ilo 42 in plasma
This must be a Samsung controller inside. Samsung controller have trouble finding if signal is ntsc or pal when tv is turn on before the source. If this is the case, just turn off the tv, start the cablebox and power on the tv again.
Jan 16, 2007 | iLO V27DMBX Television
Televison & Video Logo
90 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
