Question about LG Dishwashers
LG - LD14AW2 Fault code 1E , Replaced pump still has fault
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
It means you have an inlet error, water is not coming in. It could be a few things.
Check to see if the valve is clogged with sentiment.
The air guide contains a flow meter, if you have hard water it could be messed up and would need replacing.
There have been several instances though where broken wires in the door have caused this problem as well. Remove the front panel and look to see if any wires are stuck in the insulation, if so splice and put insulation (white) behind them so it doesn't happen again. Chances are this will be the cause.
Sgt 48
Posted on Jun 13, 2008
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
Error FE on a LG WD 1274FHB what does it mean?
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Feb 15, 2015 | LG Washing Machines
HOW to fix E1 code for LG direct drive washing machine
Aug 25, 2014 | LG Washing Machines
It's showing an error message, 1E?
The manufacturer has assigned the 1E error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve. This is the electrically operated valve that allows water into the machine when required.
Jul 11, 2014 | LG LDF6810ST Stainless Steel Built-in...
1E error code
The IE fault code indicates that your washer is not filling properly with water.
Jul 02, 2009 | LG WD-1280FHD Front Load Washer
Dishwashers Logo
262 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
