Question about Hoover Vacuums
There is no air flow from our vauum - Hoover Vacuums
  • 77 Answers
Check the hose and the power head for clogs. also change belts at 6 monthhs to keep roller moving fast enough.
J
Posted on Jun 13, 2008
No suction. What should I do?
Clean the filters first and make sure they are completely dry before putting them back in. also you can check for blockages. flip the vauum over and remove the base plate with a flat head screw driver, on the spots where applicable. once you are able to remove it. look inside see is you see any thing in the way of the air flow.
another place to check is the cyclone. if you were to open the bin as if you were dump the contents in it, you can actually see inside the cyclone. look in there and see if you can see the cyclonic holes. they sould be easily visible. if they arent or you see that they are plugged up then you know that you cyclone is clogged and it needs to be replaced. they run about $80 bucks.
now depending on your model, there is another point you can check. if you are look at the vacuum face to face if you will they have what i call the intake pivot. its near the base of the vacuum. now this pivot can be removed by pinching the 2 gray buttons on the side and by pulling up. i would look inside there as well. i hope that helped.
Sep 19, 2011 | Dyson Vacuums
No suction and performance indicator light is on
You probably dnot have a proper seal. When you change the bag make sure you close the vauum body tight. Any leaking of air will cause the vac. to lose suction. Vacuum simply means no air. Turn the machine on then listen or try to feel if there is any air escaping. Hope this helps, Chris
Feb 07, 2011 | Kenmore Vacuums
I press the on/off switch on the Dyson DC05 and the vauum cleaner switches on unfortunately when I stop pressing it it switches off again. Please advise how I would need to repair this. Many...
If you can make it work by holding the switch down then it must be the switch or a bad connection on it. The only way to find out is unplug the machine from the mains and remove the switch to check it. A replacement should be cheap enough.
pete.
Dec 24, 2010 | Dyson DC05 Cylinder Bagless Canister...
My vauum will not pick up anything. i have checked all places.
Check your hose from the end to end, you have to have something stuck in there. If its clear then your motor is not vacuuming. Also is the belt broke that spins the brush?
Nov 06, 2009 | Euro-Pro Fantom FM740 Upright Vacuum
Problems with Eureka 5892AVZ Bagless Upright Cyclonic Vacuum? the cat hair seems to plug up the filter instead of goint to the canister
You may be using the wand/hose without an attachment on it. The attachments on my dyson always allow some air to flow to by, it may be the same on the Eureka. If air flow is completely stopped the cyclone will shut down and then the hair/dust/whatever will flow to the filter. So don't let the air flow be completely shut off during use.
May 15, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Buzzing sound
You ether have an air restriction, or your bypass valve is broken. If it is an air restriction: The motor requires more air flow to stay cool, the noise you hear is an emergency air inlet made to prevent overheating. You may need to use the hepa bag to help increase the air flow. Some hose attachments will cause this to happen, your performance indicator light (if you have one) should also be illuminated if it is an air flow issue. Check your hose for a blockage.
Jan 24, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Blocked vacuum hose
You'll need a sturdy stick like a thick bamboo stick to push this out but remove the hose FIRST from the vacuum and compact the hose up before inserting the stick. Either that or you may have to order a new hose which can be cheap. What model is it you have?
May 09, 2008 | Vacuums
Vacuums Logo
37 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
