Question about HP LaserJet 3055 All-In-One Printer
HP 3055 AIO prevents boot-up / causes lock-ups in Win2000
Hello Gents,
I am running Win2000 on an Athlon/MSI board, 523 MB RAM, 80 Gb HDD and have recently purchased and installed an HP 3055 AIO.
I have loaded the full install of the HP 3055 AIO drivers and applications, but not the READIRIS PRO software (which caused no end of problems on a previous HP machine).
PROBLEM #1
Upon boot-up the Win2000 splash screen comes on but the progress bar stops at about the 2/3rds point --- ****-cold.
In order to get the machine to boot up, you have to reboot the machine and unplug the usb printer cable.
Once booted, the PC works normally and you can obtain printed hardcopies by plugging in the USB cable for the HP 3055 and hitting print.
PROBLEM #2
Occasionally, when using WordPerfect 9.0, while the HP 3055 is connected, particularly when a part of highlighted text is being cut and pasted, the machine locks up or freezes. The mouse cursor freezes in place and what you have is a complete lock-up.
The machine will not respond to a Ctrl-Alt-Del reboot command and must be restarted in order to clear the error.
This new machine is intended to increase productivity, not give rise to an endless series of headaches. Please advise.
Sledgehammer is standing by.
Kopfjaeger reporting back.
Rotated this printer to a secondary machine.
Found I could make it work through a kludge.
I have a four-device USB switchbox. The top or normal position switch is on an empty connector (A). After booting the machine and getting to a point when I need to print, then I switch to B, where the printer is connected.
Print and move on.
Sometimes will have to use the STOP USB DEVICE, and then switch back to A in order to shut the machine down without freezing.
Pretty unsatisfactory and I wonder what brainchild coded the driver software to be such a pain with Win2000.
Next time, I will be looking at *other* (Non-HP) printers much more closely.
Posted on Sep 11, 2008
"FORMATTER BOARD?"
English please. Never heard of this creature.
Is that like 100 yards of Flight Line or a Flagpole key?
Posted on Jun 13, 2008
  • 35 Answers
REPLACE IN THIS ORDER.
CABEL(CHEAPEST)
IF THAT DOES NOT WORK
IT NEEDS A FORMATTER BOARD.
2 Suggested Answers
SOURCE: HP 3055 prevents boot up in Win2000, causes lockup when connected
Actually I deleted the PCL 6 drivers which had been installed by the original HP driver CD, went to the HP website and downloaded the PCL 5e drivers instead.
I also added a USB switchbox between the PC and Printer, leaving the default setting as disconnected. Now, it boots up fine, without having the HP printer connected.
In use, I wait until just before I need to print a document, switch the USB selector to connected and obtain hardcopies of my documents.
Then, to ensure against screen lockups / freezing, I switch the USB selector back to disconnected.
It's a kludge and not what you should have to do for a $400 laser printer AIO device.
Naturally, I am completely unimpressed with HP software engineers, who have a functionality somewhat below Dilbert and his crew.
Posted on Jun 21, 2008
Boot problems
SOURCE:No boot No video on new built pc with a msi motherboard a55m-p33 amd, three beeps at start up.
Hello here is the homepage:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Driver&os=Win8%2064
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Tree beeps means you have a ram module failure, or not inserted correctly.
This mainboard uses DDR3 ram, up to 16 gb.
Try to start with only one module at the time.
Try also to check the manual:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Manual
Jan 14, 2014 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
I have msi 7528 mother board .......but display can,t show ....whats the problem
Hello here is the mainboards homepage:
http://www.msi.com/product/mb/G31M3-F.html#/?div=Driver&os=All
The manual:
http://www.msi.com/product/mb/G31M3-F.html#/?div=Manual
No display is often caused by a wrong ram module.
I mean the mhz is wrong.
Your mainboard uses DDR2 667/800 if a higher mhz ram is inserted this can cause no display.
If the cpu fan is running, its the ram module that causes this issue.
But of course it could also be the power supply, or a bad graphic card.
Try to boot up with only one module, and make sure the module is correctly inserted in the slot.
Good luck
Sep 18, 2013 | Computers & Internet
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
How do i read the motherboard to see what board i have
The Manufacturer of the mother board is MSI and details are as follows:
Manufacturer Part # :K9MM-V
Product Type :Motherboard
Form Factor/chase: Micro ATX
Chipset Type :VIA UniChrome Pro K8M800 / VIA VT8237R Plus
Multi Core Support :Dual Core
Max Bus Speed :800 MHz
Socket Type 0 ( 1 ) :- Socket AM2
Compatible Processors : Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
It supports 64 Bit Processor
Multi Core Support :Dual-Core
Its Supports RAM Technology: DDR II SDRAM
RAM Installation : 0 MB / 2 GB (max)
Supported RAM Speed :PC2-4300, PC2-6400, PC2-5300
RAM Features :Two DDR Channels
Video Memory :Shared video memory (UMA)
Audio Codec :Realtek ALC655
Sound Output Mode : 5.1 channel surround
Expansion Slots Total (Free) :1 processor - Socket AM2
You can addin RAM of :2 memory ( 1.8 V ) - DIMM 240-pin
PCI :3 PCI ( 3.3 V/ 5 V )
Storage Interfaces
Additional Connectors : 4 x Hi-Speed USB
Dec 21, 2009 | MSI K9MM-V Motherboard
Hi, when i boot the system nothing appear on the system. i initially checked my ram it was not workinhg so i bought a new one but still the system won't start up!! it is a p4, intel d865, 512 ddr ram ,...
If you doesn't hear any beeps, at least you must hear one beep.
Clear CMOS or remove the Lithium Battery CR2032 in the motherboard about 1 minute, to know which MB is hang up with processor, then put it back again & power it on.
Aug 17, 2009 | Personal COMPUTER - LENOVO THINKCENTRE A61...
Long POST and will not mount HDD.
first of all, you need to another 512Mb of memoires. it will run better. second, go to BIOS and search for boot order, chaneg the the boot order to Hard driver first.
May 01, 2009 | Computers & Internet
Hello , I just bought an 80 gb hdd. I installed it to a MS 6119 ver 1.2 bx2 board, but its not picking in bios. But with Winxp it picks up when I start up the pc with xp cd, it picks up the 80 gb hard disk...
I am ArmyMason and I believe the issue is the hard drive is too large for the system you have. That board is old and back in the day they didnt support large hard drives. You could try using a boot disk and partition the hard drive into 20 GB drives and see if that works.
http://global.msi.com.tw/index.php?func=proddesc&prod_no=332&maincat_no=1
Link to specs.
Thanks ArmyMason
Feb 24, 2009 | Computers & Internet
Jun 11, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
