Question about Sierra Wireless Aircard 860 PC Card (SIASIERRAWIRELESSAIRCARD860P)
Air card (usb connect881)
My air card is not working properly, is too slow and is very difficult to find the network, Will you help me to solve this problem?
Nelson
  • 611 Answers
I think that your network range is not there so you not working properly eithere re-installed the driver of the air card or download a latested ver of the driver from the internet.
Posted on Jun 13, 2008
I have a poulan 14 inch woodshark chainsaw and it ran fine when i got it but now i have to keep gunning the gas to keep it running and i have cleaned the air filter and cleaned the carb.
Turn up your low speed jet about 1/4 turn. You have 2 holes in the side, one says slow or low and the other says high,, or fast, turn the slow jet in 1/4 or out if that doesn't work, then try it, you will find the right spot. Hope this helps.
Mar 13, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
It connects and but time with very slow and show
It's always difficult to troubleshoot wireless because the signal can be effected by so many different variables. Easiest thing would be to connect another wireless device. If that works OK then it's your computer or wireless adapter. If that drops out too then it's your wireless router. When we find out what's at fault we can find a more detailed solution if you' be kind enough to post back.
Dec 12, 2009 | Computers & Internet
Tune a ryobi two stroke motor
Turn Both Air Mixture Screws In Until Seated. **DO NOT JAM SNUG ONLY** Turn Both Screws Out 1 1/2 Turns. Set the Throttle to Full Open and Start the Engine. Override the Throttle by Pushing the Governor Arm by Hand and Turn the High Air Mixture Screw(bottom of the bowl) In Until the Engine is Revving Properly. Now Slow Engine to Idle. Set the Low Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Now Set the Idle if Required.
Nov 09, 2009 | Electronics - Others
No wireless network
I also have the Inspirion 9100. It is very finicky, try going thru the Setup wizard again and reset-up your wireless connection. If that doesn't do it...you might get a can of compressed air and use in the wireless card slot (if your using a wireless card), the bottom and on the keyboard. Surprisingly enough, I did the keyboard and the underside of the unit and it solved several minor lingering hardware problems.
Jan 14, 2009 | Dell Inspiron 9100 Notebook
I will be traveling in asia and I want to get international internet wireless that will work anywhere in asia.
Check with Verizon, they have air cards that work internationally. I used mine in Haifa, Isreal.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 13, 2008 | Computers & Internet
Motherboard dosent working
hi buddy!
maybe the sucket of fan for processor have a problem try to change slot ok this is possible you find that slot is working fine ok.thnx
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 22, 2008 | Acer Computers & Internet
Air card
yes they are called usb network sticks
May 26, 2008 | Dell Latitude D600 Notebook
DWL-122 driver not installing, device not recognized
The wireless adapter will not show on the My Computer. Try to right click the My Computer icon go to properties, then go to Hardware tab then click the device manager button, click the + sign beside the Network Adapters category and check if you have the adapter listed there. If the adapter is listed check if the driver is installed properly by going to the properties of the card.
May 21, 2008 | D-Link Air DWL-122 802.11b Wireless...
Staying connected to internet, using sprint 595 air card
If I were you, I would let your windows manage your wireless network on the computer with vista. Also you might, If you haven't already tried using your install new programs in the control panel, As long as you have the sprint software downloaded in your laptop windows should still recognize the wireless connection, Try letting windows manage it from the Network properties and there should be an option there that lets windows manage you network. try it see if that helps you out. If not write back here and let me know we can try another route. Sorry you having problems.
Jan 09, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
61 people viewed this question
Top Sierra Wireless Computers & Internet Experts
Jerry Umali
Are you a Sierra Wireless Computer and Internet Expert? Answer questions, earn points and help others
