Question about GE Heating & Cooling
GE air conditioner ASM08LLS1 Problem: Cannot remove air conditioner from its casing. Both Phillips head screws have been removed from sides of casing. Instructions say, "slide the air conditioner from the case by gripping the base pan handle and pulling forward while bracing the case. Fact: there is no base pan handle. there is nothing to hold on to. Nothing. Please advise. Soon. It's hot today. Leonard
    Genius:
  • 1,554 Answers
If its in a window make sure no one put a screw on the outside when mounting it.
it takes 2 to pull one out sometimes as the water ,goop ,rust gets under the tray.
I assume you removed the front.
the base pan is all you can really pull on hard but you can do some pulling on the sides just be gentle. lol.
Posted on Jun 13, 2008
How to take off side panels?
2 Phillips screws recessed where hands go to lift unit. Then remove 4 plastic caps and 4 screws on each side. Sides should drop down 1/2 inch once screws are off that allows removal.
Apr 20, 2014 | DeLonghi Heating & Cooling
How to clean the fan in my laptop
As with any hardware on your laptop, the fan may stop working. Your laptop's fan serves as the dedicated cooling system for the CPU. If your CPU overheats it will cause severe damage to the motherboard. It may also cause electrical damage hardware devices nearby the CPU. Most HP laptops are designed with CPU fan located on the top side of the motherboard. There are a few HP laptops with the CPU fan located on the bottom side of the motherboard.
Shut down your laptop, and fold down the LCD screen. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Disconnect the AC power cable and any external devices. Place the laptop face down, and rotate the computer so the front opening is facing forward. Locate the battery pack in the upper right or left corner of the laptop. The location depends on your laptop model. Press on the battery's release button, and then lift the battery out of its compartment. Place the laptop face up and open the LCD screen all the way. Insert a flat-head screwdriver into the right side of the keyboard cover. The keyboard cover is a thin strip of plastic situated between the keyboard and LCD. Gently pry the cover from the laptop, and set it aside. Remove the Phillips-head screws located above the top row of keyboard keys. These screws secure the keyboard in place. Grasp the top edge of the keyboard, and then place the keyboard face down over the palm rest area. Disconnect the keyboard's large ribbon cable from the motherboard. Remove the keyboard from the laptop. Locate the small circuit board near the top of the laptop's upper casing above the keyboard compartment. Disconnect the cables from the circuit board. Remove the Phillips-head screws securing the circuit board in place. Close the LCD screen. Place the laptop vertically. Position the laptop with the back of the LCD hinges facing upward. Remove the single Phillips-head screw from the back of each LCD hinge. Place the laptop face up, and open the LCD screen until it is in the 180-degree position. Locate the LCD video cable extending from the left side of the LCD panel. Disconnect the cable from the motherboard. Remove the Phillips-head screws from each LCD hinge. Lift the LCD screen panel off of the laptop. Set it aside. Locate the CD/DVD drive inside the right section of the laptop's upper casing. Remove the Phillips-head screws securing the drive in place. Grasp the face of the drive and slide it out of its compartment. Place the laptop face down. Remove all remaining Phillips-head screws from the bottom casing of the laptop. This includes any screws inside the battery compartment, and on the back panel of the laptop. Flip the laptop over, and remove the remaining Phillips-head screws from the laptop's top casing. Locate the touchpad cable situated just above the touchpad area. Disconnect the cable from the motherboard. Remove the top casing from the laptop's base. Locate the CPU fan in the upper left corner of the motherboard. Remove the Phillips-head screws securing the fan to the motherboard. Disconnect the fan's power cable from its connector on the motherboard. Lift the cooling fan out of the laptop and set it aside. http://www.youtube.com/watch?v=qcy0YSOmX4E How to Clean the Fans on HP DV4 - Overheating This might not be you laptop but it might give you some insight. Hope this helps.
Jan 09, 2013 | Computers & Internet
My olimpia spledid piu Air Conditioner is flashing 8 on the display screen, it wont turn on at all. Anyone know what it means or how to fix it
In our case this error means that the grandkids have jammed jigsaw puzzle pieces in the main blower at the front. The manual says to return to service centre for repair. If you've got a philips head screwdriver, you can fix it yourself. First REMOVE POWER CORD FROM WALL. Remove back cover, undo 7 phillips head screws, note the bottom 2 are longer for assembly. Remove front cover by undoing 3 screws on each side. Be careful with fine ribbon cable you can unplug it at the connector on the unit. Remove whatever has jammed the main blower, in our case it was jigsaw puzzle pieces, that could not be seen when the unit was assembled. Replace front cover, don't forget the ribbon cable. The front cover sort of goes back on from the bottom front first, and is snug over the top. Replace back cover, (remove dust from internal radiator fins first). Leave turned off for an hour or so if you had the unit upside down to remove blockage. Boom you just saved yourself a couple of hundred bucks probably.
Jan 03, 2012 | Heating & Cooling
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
How do i disassemble to access motherboard and DC jack
Me too, need to get inside to clean and remove dust and see why my video is gone after about 10 minutes of operation or so, good chance it is an overheating problem, but I cant get the case open.
May 19, 2010 | E-Machines M5414 Notebook
Whats the procedure for changeing air filters in a yamaha royal star tour deluxe 2005
This procedure must be performed on both sides - you'll find the air filter cases mounted high, immediately behind the cowlings. Yamaha specifies removing the cowlings, but I just remove the top screw in the front of the cowling and bend it forward slightly to get to screws and bolts.
The air cleaner cases are mounted by hex-head screws top and bottom; loosen them, then look for a large rubber hose from the case to a duct beside the case. The case is held by a flexible clamp with a phillips-head screw adjustment - loosen the screw and the case can be removed.
Turn the case so that the rubber hose is facing up; there are five screws holding the case halves together. Remove them to split the case. The filter is secured to the side of the case that the rubber hose joins, loosen the two screws in the front (forward-facing) of the filter and remove.
Secure new filter with the screws that held the old one, rejoin the case halves, put the case behind the cowling, secure the rubber hose to the duct, screw top and bottom bolts through the case to their mounts, tighten cowling mounts.
Repeat on the other side and you're done!
Mar 04, 2010 | 2005 Yamaha Royal Star Tour Deluxe
Cooles but will not heat
heat strip is possibly burnt out and will need to be replaced. The strip sits inside the unit right behind the evaporator coil, To access the heat strip you will need to remove the unit from its casing and place it on a level surface.. The heat strip is possibly in a metal casing and the heat strips look like the heat strips in a toaster. The assembly comes out by removal of a few phillips head screws and has an electrical disconnect plug that powers the coil. Take the coil assembly along with the model and serial number to the nearest appliance parts house for replacement part. Good Luck hope this helped you somewhat
Dave
Nov 09, 2009 | Maytag M6D24E7A Air Conditioner
How do you change the air filters in the Royal Star Tour Deluxe?
if you don't see an air box prominent...remove your saddle and the airbox and filter is under the saddle...your bike manual should cover this
Jul 21, 2009 | 2008 Yamaha Royal Star Tour Deluxe
Heating & Cooling Logo
88 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
