Question about Panasonic DMR-E85H DVD Recorder
Power does not come on (there was a second break in power supply and the recorder did not come on after that)
    Genius:
  • 1,175 Answers
Try unplugging the AC cord and let it sit for 30 minutes then try it again
Posted on Nov 03, 2010
  • gupta_vineet Nov 03, 2010
    i have unplugged and let it wait actually for an hour and still does not power up
  • Scott Frye
    Scott Frye Nov 03, 2010
    There may be a small glass fuse inside ( 5x20mm) You'd have to UNPLUG the AC and take the top case off to check.
    The fuse is about 5/8 inch long with metal caps and glass in between
    There should be a thin wire inside from end to end. If that is broken then your player wont work
    Replace fuse
I have purchsed (Sony Bravia LCD KLV-32 bx300). when i plug it in The standby indicator then flashes (red) five(5) times then there is a two - three seconds break followed by another five flashes then a...
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also, look for popped capacitors that would make the values lower than need be for the tv to power on properly.
After you repair the power supply's capacitors you may need to replace other components if needed
BUT always start at the root of the problem (power supply) and work your way to other components
Please rate if this helps :)
Mar 08, 2011 | Sony V SERIES BRAVIA KLV32V300 32 in. LCD...
I have changed the break switch and checked the fuse and light bulbs and still no break light.
Without knowing the exact year of the chrysler, I will only suggest some diagnostic ideas. One thing to remember is that Chrysler vehicles use the signal switch that is located in the steering colum to channel power to the rear brake lamps. The signal and break light elements are the same and the power supply is turned on and off as required using the signal switch as well as the break switch. Check the power supplies coming out of the steering colum. There is a connector in the lower region of the steering colum that will allow a power supply check. You may have to include more vehicle information on your next diagnostic request.
Cheers.
Feb 21, 2011 | Chrysler Town and Country Cars & Trucks
The power won't stay on when the power button is pushed. I've tried blowing it out to see if it's just dirt but I think the connection is just not working with the button.
when you press the power button is there a light indicator or the machine turn on even for a few seconds. if not maybe its the power supply or the power cord.
it could be internal problem
if you want to fix let me know
ecrdn@yahoo.com
Jack
Nov 04, 2010 | Panasonic RR-830 Desktop Cassette...
Power off after recording
Hi All,
This is a power supply problem.... the MR2920 stanby IC miss behaved, it power off and fail to power back on.
Solution, get pioneer power supply replacement or take the dvd recorder to your local electronic service repair to take a look at the power supply circuit.
Best of luck
Kenny
Apr 21, 2009 | Pioneer DVR-520H DVD Recorder
Monitor blinks off for about two seconds and loses power.
This problem sounds like a failure of the monitor power supply switching transistors breaking down under load conditions.This unit needs to be taken to a service center for repair. It also could be other intermittent components affecting the power supplied to the monitor. Hope this helps.
Apr 07, 2009 | Computers & Internet
Code u61 panasonic dvd recorder
Reset the unit as follows:
Press [POWER í/I] on the main unit to switch the unit to standby.
If the unit doesn’t switch to standby, press and hold [POWER í/I] on the main unit for about
10 seconds. The unit is forcibly switched to standby.
Alternatively, disconnect the AC power supply cord, wait one minute, then reconnect it
Mar 01, 2009 | Panasonic DMR-E85H DVD Recorder
Will not record or play back VHS for more than 30 seconds
I can tell you some ideas genericaly for VCR's.
This could be an idler wheel assembly problem, or a tape tension, or a reel torque problem.
It can also be a power supply problem where the supply is working just on the edge. Due to some worn components in the supply it can be partialy shutting down.
Your machine will have to be checked out by an experienced VCR tech.
Jerry G.
Dec 04, 2008 | Radio Shack Accurian ADR-0106
CYBERHOME DVD RECORDER DVR1600 - Need Power Supply
Bill,
I can rebuild your power supply if it is not in aches. A Compute power supply works with these unit if you know how to modify it.
May 22, 2008 | Cyberhome DVD Recorder - DVR1600
Panasonic DMR-E85H DVD Recorder Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
