Question about Gateway EV910B Monitor
Gateway EV910B monitor power requirements
I have a 19' EV910B monitor that I had bought in the USA. The electrical rating label says it can run on 110 to 240 volts. I am now in a country that uses 220 voltage. However, before I simply plug it in and fry it, does anyone know if there is a voltage toggle switch somewhere on the monitor? I had an older Gateway monitor that did have a toggle, so that you could use it in either a 110 or 220 voltage situation, but the toggle had to be set correctly. However, I can't seem to find one on the EV910B. Can anyone confirm if there is such a toggle switch or not? Thanks.
  • 426 Answers
I dont think there is but there might be a switch inside the housing of the screen i would call gateway! it was sold with a 115v power cord so its proabaly factory set to use 115v you might however be able to change it? if you open the cover to the screen please make sure you know what you are doing TOUCHING THE WRONG THING CAN/WILL KILL YOU!!!!! please be careful :)
Posted on Jun 13, 2008
Will my toshiba tv bought in uk work in usa
There are two things you need to know regarding your TV.
Power requirements and broadcasting standards.
1:POWER
Look on the back of the TV and find the sticker or label that mentions the INPUT VOLTAGE.
If it reads 220-240V 50Hz then it will not work in the USA.
If it reads 110-240V 50-60Hz then it MAY work in the USA. At least you know it will work if you change the plug on the mains cable.
2: BROADCASTING
In the UK, broadcasts use the PAL system to display images on the screen. In the USA, broadcasts use the NTSC system to display images on the screen.
You need to check the manual that came with your TV to see if it is capable of receiving an NTSC signal. This signal is used in everything in the USA from PVRs, to DVD/HDD recorders, satellite systems, public access and cable systems.
If your TV meets the power and broadcast requirements then it should work.
May 24, 2015 | Toshiba 50H82 50" Rear Projection...
Bl1815 wont charge
i bought a new makita cordless drill in united states of america brought it home to the republic of ireland got a 110 adopter to recharge the battery but it will not hold the charge would it be the flight home have wiped the batterys what do i do?
Feb 07, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
http://www.cheaperoz.com/z/result.jsp?ga=sc1&q=19v+power+adapter
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
I bought an AOC 2036s monitor in the usa, came back to australia to connect it to my laptop as a second screen. yet it wont seem to work, i keep getting no signal. the box saids compatible with XP, yet...
USA mains equipment operate on 110 volts. Unless the AOC monitor can operate on multi voltages ie 110 to 240 volts, when you connect 110 voltage equipment into 240 volts mains in Australia you most likely will damage the AOC monitor.
To operate equipment that has been designed for 110 volts, you need to purchase a step down transformer from 240 to 110 volts that has suitable wattage rating for the AOC monitor.
Feb 24, 2011 | Computers & Internet
A 220 volt Amstrad monitor that i want to convert to use 110 volt
engagetek, This would be a very easy thing to do if and only if the label on the rear of the unit has printing similar to my GATEWAY LCD. It states as follows: "100 - 240VAC input 50/60hz." If your Amstrad unit's label reads "220-240VAC 50/60hz only, then you will need to reverse engineer the "ac to dc" power supply, be it an old "linear" or a modern "switch-mode-power-supply" type. You did not state what type of monitor technology your Amstrad is. CRT, LCD, Plasma,???? I would guess that it is a CRT type. Well anyway, I hope the info was of some use. Bye for now, I'm louie12fix on fixya
Oct 11, 2009 | Computers & Internet
Light flashing
Try another monitor on your computer to make sure that your computer is booting up properly.
If your running into the same problem with a known good working monitor then the computer is the problem.
If the known working monitor turns on then you know the original monitor is bad.
Sep 03, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor screen
Try pressing and holding Ctrl, Alt and then any of the four arrow keys (Example:Ctrl-Alt-Down will rotate screen by 180 degrees)
Sincerely, CBR2009
Dec 06, 2007 | Gateway EV910B Monitor
it is monitor fault and you will not be able to solve it is better to show the repair personnel.
Sep 22, 2007 | Gateway EV910B Monitor
Computers & Internet Logo
107 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
