Step 1: Restart your computer during the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show. Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
During the boot process tap thef8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computerAdvanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show. Log in as "Administrator". Click Yes to not use System Restore Mode.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure placeClose the User Accounts window and restart Windows. hope this helps you
Please follow the steps to disable the Touchpad under XP environment:
First, click the Start button, then click VAIO Support Central . In the VAIO Support Central window, in the left pane , click System Maintenance . In the right pane , click VAIO Central . In the VAIO Central window, click the System Information tab. On the System Information tab, click the Plus symbol next to Keyboard and Mouse . Under Keyboard and Mouse , double-click Built-in Pointing Device . In the Built-in Pointing Device window, click to clear the Enable box. Click the OK button. In the Built-in Pointing Device dialog box, click the Yes button.
If you can bott the computer normally and don't have to type a password in, then go the control panel and then choose device manager. Scroll down to the mouse and keyboard plus signs and right click on the mouse and keyboard one at a time and select uninstall. When the original mouse and keyboard have been uninstalled, reboot the computer. When Windows starts back up it will be forced to search for the new hardware and will install the drivers for it. If it wants to search for new ones allow it. If you have to type a password, you will have to go and get a usb keyboard that works off one of the usb ports. If this doesn't work, reboot the computer with the Vista disc in. Click any button to boot from the cd. When the windows files load and windows starts, choose repair, choose the windows installation and let windows search for problems and see if it can fix them. If all fails, go to system restore and back the computer up a few days and let system restore fix the problem by taking you back in time a few.
windows xp info. go to start, control panel, systems, hardware, device manger, click on x at keyboard see your keyboard there right click delete keyboard shut down and reboot leave keyboard plugged in...and it should find and reload the keyboard.
if this does not fix the problem..shutdown the computer unplug the keyboard and mouse...reboot the computer and let load all the way...I know you can't do nothing about signing in or working on it but let load all the way after finished loading push button to power it off are unplug it...then replug the keyboard and mouse and boot it back up should fix it...
Try booting your computer from CD ROM with the OS CD/DVD already inserted and when prompted just try repair. If that does not work re-install the same on the same 'partition' assuming it to be C by deleting the the windows system files only. While doing so keep the internet on and immediately after the basic version of the OS is installed and the m/c boots-up for the first time, go to the official website and download the latest drivers for every component like toch-pad, keypad, display, audio, etc.(i.e. almost all the drivers)
Sounds like a mouse driver error. Try unplugging the mouse and booting with only the keyboard connected. Once you've typed in your password and logged-in you will need to 1) delete the existing mouse driver and 2) plug your mouse in and let Windows discover the new hardware. Use the recommended driver and reboot your system after it's finished installing.
Let your computer boot as normal.Go to Device manager>under keyboards your wireless keyboard should show. If its not there reload it from the set up disc that came with your hardware i.e keyboard and mouse.If its listed enable it or uninstall and reinstall.
