Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony kdp-51ws550 10 blinks
No power 10 blinks code
  • 2 more comments
  • Anonymous Jun 24, 2008
    blinks 10 times, No video, hear the relay kick in then kicks out.
    Please help
    Thanks,
    Pat
  • ddaniel0926 Jul 03, 2008
    My kdp-51ws550, when you turn it on, sometimes the sound will come on, but the video doesn't. then the front light blinks 10 times. From time to time it will come on but I have to leave it on or I have no tv. With kids and lightning storms it is hard to do.
  • bikesr4me Aug 10, 2008
    I have the same problem except after turning the set back on a few times it will stay on for a few hours. The weird thing is if it stays on every evening about 8:00 it will start shutting off every few minutes. If you have any ideas let me know. Thanks
  • Larry Meadows Aug 19, 2008
    My kdp-51ws550, when you turn it on, sometimes the sound will come on, but the video doesn't. then the front light blinks 10 times. From time to time it will come on but I have to leave it on or I have no tv. With lightning storms it is hard to do. The service man said the D-CARD is bad. No longer availible.
    Lmeadows
3 Suggested Answers
villamore
  • 27 Answers
SOURCE: sony kdp-51w550 no pic. no sound. blinking light in front
checked power supply section
Posted on Jul 30, 2009
  • 3230 Answers
SOURCE: i have a sony color
Well If you simply push the power button on the front, does the stand-by LED turn off or start flashing? Anyway the G Board is definitely suspect. Try measuring the 5 volt DC stand-by power supply. That is best done at connector CN605, between pin 10 and cold ground (any metal chassis part).
If that voltage isn't there, carefully measure the voltage across resistor R607 ( not to any ground). You should get something very low, a couple of volts (if that much). If you get a couple hundred volts, that resistor is open, and that happened because transistor Q601 shorted.
Note. You need a ohms meter to check that all. please do not try this if you do not know how to do that.......
Please post comments for more help or information........
Good Luck!!
Thanks
Posted on Jan 05, 2010
Sony HD Projection TV KDP-57WS550, timer light blinks 5 times and repeats sequence. When power button is pushed sound comes on briefly, no picture, then TV goes off. Please advise.
Mine did this after a power flash. Lights blinking 5 or 6. They blink fast lol. I have sound till tv powers back down. Front yard bond fire? Or any ideas? Thx.
Dec 25, 2010 | Sony Grand WEGA KDP-57WS550 57" Rear...
Hello, I have a problem with my sony rear projection tv. When I try to turn it on the standby lights blink but it odes not turn on. I turned it on using display 5 vol- power and it did turn on and know it...
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero cross failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they either repair and return or ship you a different repaired board) A new board costs about $80- without having to send them your board.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-2.jpg Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-5.jpg Component D6301 location (Sony KDP-51WS55)
problem-4ojfzua2t5qdonett1db0kz0-5-9.jpg Component D6116 location (Sony KDP-51WS55)
Sep 11, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Kdp-57ws550 10 blinks
10 blinks means Power supply problem,google Understanding Sony Blinking Codes.
May 13, 2010 | Televison & Video
Sony KDP-51WS6755 not turning on, power surge, pop, 6 blinks.
unplug it immediately. never tolerate a sizzle (frying noise) or a popping noise. do NOT replug. fire hazard.
contact serviceman for repairs. Sears Home Service can handle this for you.
Apr 14, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
My Sony KDP-51WS550 wont turn on anymore. The Standby light is flasshing 10 times.....Any ideas about what happened and how to fix?
Type in space bar Understanding sony Blinking codes this will take you to a website telling you what each code means.
Nov 13, 2009 | Sony Grand WEGA KDP-51WS550 51" Rear...
My tv wont come on, i
Type in Sony Blinking Codes.This will tell you what they mean.
Jul 20, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
SONY KDP-65WS550 projection or power problems NEED HELP
3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode. got this off a website that had Sony codes listed.
Rusty
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Won't turn on.
My Sony KDP is blinking 6 times. My guess is the blinking is a troubleshooting code. We just need to located the chart to describe the blinks.
Sep 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
821 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
