Question about Numark TT1610 Turntable
I need help! the center spindle I think its called "wobbles" the whole table wobbles and I can't mix or cue or anything at all without jumping to a different spot on the record...how to I tighten it up or somthing...just stop it from wobbling..PLEASE SAVE ME IM DYIN!
GOT IT! on the underside of the turntable there are about nine screws i think and if you take them out and remove the bottom there will be a bunch of wires. in the very center, directly behind where the spindle is there is a screw with a bolt around it and a wire under tho bolt. this bolt is probably loose, tighten it with a 9/32 and reattach the bottom with the screws, you are good to go. (by the way the gurus on this website arent the best at this, i could've did what they told me to do by myself)
Posted on Jan 02, 2011
Same iv got the same deck as you and the same problem have you figured it out yet
Posted on Dec 20, 2010
  • AlecJohnson Jan 02, 2011
    i have the same problem, i was debating trying to open it up and see if there was anything i can do. have you asked anyone or took it to a repair shop?
  • arctic_ollie Jan 05, 2011
    i got mine from decks.co.uk and i just went into the store and they fixed it for me for free :)
I have a Craftman DLT3000. The righthand blade is out of level. Deck is level and left blade cuts flat to the plane but right blade is canted.
You will need to find a way to level the spindle if the shafts isn't bent, remove belt and release spindle brake then spin blade and check for wobble. If you have shafts wobble replace spindle. If no wobble find a block of wood that fits snugly between good blade and concrete floor or drive. Check all blades for height from floor if center is the only one that has a different height then you will need to loosen spindle ,place some type of metal shim under low side , re-tighten and re-check. If other blades show difference on one side , you may have a bent blade or spindle or spindle mounting on them. The deck is sheet metal and can be bent when a foreign object is struck. There are also deck levelers on the supports. If the front of mower is up or down it will cause a high or low center blade path of cutting. All blades should be as close to the same height from a level surface as possible. This is time consuming but the only way other than new deck and/or spindles and blades.
May 03, 2018 | Craftsman Garden
The plate on my numark tt USB is wobbiling
I find it hard to believe some of these answers. If the platter is wobbling, if you remove the platter, you'll find the spindle the platter rotates on. That will probably be loose. At the bottom of the spindle bearing, you will find a nut. Tighten that, and you should be in business. If you have further questions please visit my website at audioserviceclinic.com. You may contact me there.
Apr 26, 2015 | Numark ttUSB Turntable
Tire wobbles
Subaru ,OK wheel bearing ,yikes I think that is a press in bearing,not an assembly like most,not a "driveway" project.
You could pull the whole spindle(,some spray paint on the strut bolt area aids in getting the alignment right later.) then take the bearing and spindle to a shop to get pressed in.
Jun 13, 2013 | Cars & Trucks
How would I know if my billiard cue is warping?
The best way to check for warping is to roll your cue along the tables' surface. If its either rolls unevenly or wobbles in any way than it is most likely warped.
Jul 25, 2012 | Sport & Outdoor - Others
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Our 2004 Kia Sedona has load noise coming from front driver side, had it to a shop a month ago and thought it might have a bad bearing but they said that was fine. There is no wobble or anything in the...
could be spindle the boss will wear out when the bearing gets worn out just replaced one on the drivers side got from salvage yard whole thing
Jan 05, 2018 | 2004 Kia Sedona
What type of cue ball does an older coin operated dynamo pool table use . it has the weighted section in the ball return ? Thanks
Weighted cue balls are most commonly used in older Dynamo pool tables. These tables actually have three methods of distinguishing cue balls from numbered balls. They have a shunt for over-sized cue balls, a magnet for magnetic cue balls and a patented designed weighted cue ball return. Billiard balls weigh 6 ounces. The slightly heavier cue ball rolls through the separation interchange, activates a rocker dropping the cue ball into the hairpin turn leading to the head of the pool table.
Apr 28, 2011 | Video Game Consoles & Games
Can not figure out where the pieces go to hold fan together (center piece) show diagram if can thank-you
If what you are calling a center piece is the safety grill, it has clips around the edges to remove the screen for service or cleaning.
If the fan is wobbling, the nut in the center of the fan needs to be tightened.
Jim Hart
Jun 20, 2010 | Optimus F-1212S Table Fan
Freezes during playback
Hi. What I am trying to establish from my last question is whether the laser has become heat sensitive or whether there is a bit of dust buildup on the spindle table that might be causing the disc to have excessive wobble.
If the disc has excessive wobble, then the machine will have trouble tracking the outer tracks and will constantly skip as you have described after say 30 to 45 minutes.
If the laser has become heat sensitive then the same problem could potentially occur - The only difference being that if you were to restart the movie at that point, then the skipping would continue even at the beginning of the movie.
The first problem (wobble) is easy to fix - Clean the spindle table, the second problem may render the unit uneconomical to repair.
Mar 16, 2010 | Samsung DVD-V5500 DVD Player/VCR
Can't Get Blade Off
without a model number I cant look at a breakdown but if it is like the table saws that I work on I would assume that you removed the center plate to get to the hex nut and spindle, if so what I have to sometimes is put my wrench on the spindle and brace it against the saw frame and using a soft mallet tap on the hex wrench to loosen the nut. After this initial blade change the hex nut has to be tight but not to the point of breaking wrenches. If this doesn't work get me the model number and I will dig deeper to try and help
Jan 01, 2009 | Skil 10" Table Saw
Numark TT1610 Turntable Logo
260 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Morne Olivier
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
