Question about Vizio P42HD Television
Visio p42hd, no picture or sound. like it just wont switch on. No led lighting (yelow, green, red) on front panel, can't turn on via remote or push button front panel. There is a test switch on a board and when switched i get a nice blue screen. Checked all fuses (7) all good. Nothing seems to be blown. Large caps looking good visually no buldging. Secondary power supply has output voltabe on pins.May be good power supplys but may be bad main board??? Both the remote and front panel buttons send signal to somewhere to switch on TV (Main Board)?? Why no led lit?? Nice blue screen comes to life when test switch is moved to test position so there is power then.
  • 1 more comment
  • spinks02 Nov 03, 2010
    Yes i am qualified. I have a major in computer science and a minor in electronics. I have repaired board level circuits. I just have not taken apart a tv in a long time. It is a plasma and I need to learn about the newer technology. I do not have a manuel and I'm not familure with the new boards but I learn quick. I would also like to know more about the test switch. i was on ebay and seen th boards #2970041206 for sale. It appears that the front panel switch wires run to this board. My guess is that once the board receives a signal it then must switch on a relay to main power.
    Thanks I'll look into getting the manules. Do you have any descriptions of the functions of the boards in these tv's. So for instance what do the following boards do: Y Sustainer Board, Z Sustainer Board, GRAPHIC PCB, Bottom Y-Driver, Y-DRIVER TOP, X-Sustainer Left XLBT, Logic Control Board etc. Im not a tv repair person but if I could understand what these boards are supposed to do then I would have a better idea of where to look.
    Thanks for all your help. I now need to move forward with a service manule. But I might go ahead and order a main board for $40. and see if the problem is solved. Thanks for the description of the board functions, that helps me out with the diagnostics.
  • 4,889 Answers
Yes it does sound like the mainboard. But we have to confirm. I will see if there is a service manual for this unit in my collection but do you think you can safely work on it? Have you worked on electronics before? The last thing I want is you hurting yourself trying to fix it. HV circuits are not to be messed with unless you know about them.
Posted on Nov 03, 2010
  • 1 more comment
  • eagle338
    eagle338 Nov 03, 2010
    You are right about the relay. That is "click" that you hear when you turn on the power, provided the power supply has not turned off due to some protection fault. As for the service manual I do not have one for this model but you can get it from the link below for 5$.
    http://www.s100-manuals.com/manualdetail...
  • eagle338
    Power/standby boards handle the power supply functions, X-sus , Y-sus boards produce the high voltages required to drive the display(discharge capacitors in tandem), driver boards perform the buffering functions, logic board handles the controls(remote control inputs and front panel controls along with the addressing functions (of the pixels) , Graphic PCB you mean main video/audio board?
  • eagle338
    Thank you for the accept. If you need any help with your daignostics feel free to ask. This thread will never expire
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Vizio P42HD Television Logo
462 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
