Question about iRiver H10 MP3 Player
H10 iriver can i format h10`s memory?
  • 8,596 Answers
See my Tips and Tricks under my profile for formatting mp3 players - there are the ways to format - one through Windows desktop, and one through Windows Media Player.
Posted on Jun 13, 2008
SOURCE: iriver (h10)
either find rockbox or iriver plus and do a firmware upgrade
Posted on Nov 19, 2007
  • 73 Answers
SOURCE: delete music H10 iriver
Sorry, but the built-in firmware only allows you to do that by plugging it into your computer as a removable device. Pull the battery of the player (or press the reset button), plug it into your computer, and press and hold the OK button as you turn it on. This will cause the computer to recognize it as an external drive, and you can therefore delete music from it by accessing it through My Computer.
Posted on Dec 25, 2007
SOURCE: Iriver H10 V's Vista
Try making sure the device is switched off before plugging it in - then turn on the power after it's connected.
Seems to've fixed the problem for me.
Posted on Aug 15, 2008
  • 3 Answers
SOURCE: lost h10 iriver installation disk
You can download the software from this site;
http://www.iriver.com.au/iriver/index.cfm?pageID=10001
Probably also from worldwide site. www.iriver.com
As a work-around you can copy files with Explorer to the Music folder and use the Browser on H10 to play them.
Posted on Mar 25, 2009
SOURCE: iriver h10 when switch on it shows system file missing connect h
I'm not sure my solution can help you or not.
I've got this message too but after I formated H10 by Windows.
First backup all files by window explorer.
Open iriver plus and go to > Option > Portable Device Initialization.
This function will delete all data, Please sure that you already backup all of your data from H10.
After initialize process finished, it will ask you to disconnect and connect it agian.
------ Steps below, I can't explain it clearly. May be you will not have the same results as me. I hope it can rise you some ideas how it comes.
I followed that instruction but after I disconnected it again and turned on, expected that msg will disappear, IT's NOT! a bit freak out.
Ok claim down,
I tried to turn it off but I can't then I pushed its battery out and put it back and turned on, that msg showed up again.
Then I connected H10 to Iriver plus again and it upgrades firmware automatically.
At the end after I disconnected and turn on my H10 it works perfectly.
I'm not a native English so my language could make you confused, any questions you can contact me. :)
Posted on Jul 28, 2009
Testimonial: "hiiiiiiii thank u for helping me really i was screwed up but know its working and about ur english is perfect bye ."
Upgrade Iriver h10 20gb with V2.51firmware
Go here:
http://www.iriver.com/index.asp?code=0302
...and search for H10; look for the correct configuration for your unit in the small-font listing under [MTP] H10 5GB/6GB/20GB Firmware V2.51 - US & EU (which is probably H10_20GC_ENG_MT.ZIP if you're in the US).
Then search the site for Firmware Updater. Dowload it, unzip it, and run iriver Firmware Updater Setup.exe. Follow the steps on the screen. You might lose your data and have to reload all of it back onto the player, though. Good luck!
Jan 15, 2010 | iRiver H10 MP3 Player
I can not delete unreadable/corrupt music(MP3) files
When your iriver H10 has corrupt files you may want to solve the issue by formatting the player's hard drive.
This is how I did it with my H10 5GB (so called 'MTP device' thats recognized by Windows as a portable device i.e. "Windows Portable devices".
To do so follow 2 steps: step 1: Format the hard drive of your H10. step 2: Re-install the player's firmware.
step 1: Format the hard drive of your H10: --------- 1. Make sure your H10 is turned off and disconnected from the computer. 2. Take out the battery, wait a second, and put the battery back in. 3. Turn on the hold switch (so that you don't accidentally turn the H10 on all the way). 4. Plug the H10 into your computer. 5. Turn on the H10 while holding the "O" button. On your H10 screen You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button. 6. On your computer, start Windows Explorer, navigate to the drive, right click and select 'Format'.
step 2: Re-install the player's firmware. --------- 1. Download and install iriver Firmware Updater v2.4.0.0. I found a downloadable copy on this website: http://www.opendrivers.com/driver/237145/iriver-firmware-updater-v2.4.0.0-for-mtp-devices-windows-free-download.html 2. Start the newly installed software and follow the Wizard. I clicked the 'USA' button when asked where I bought the device. This should install the MTP firmware. 3. Wait for the software to complete and disconnect your device from the computer. 4. Wait for your device to install the new Firmware.
Oct 01, 2009 | iRiver H10 MP3 Player
Iriver h10 when switch on it shows system file missing connect h
Ok claim down,
Jul 16, 2009 | iRiver H10 MP3 Player
System files missing
I got this from another post:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Also go here for the firmware directly: http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 13, 2009 | iRiver H10 MP3 Player
I fixed this problem for my mate, here's what I did:
hope this helps.
Here is for the Iriver H10 software:
Restore the system files, connect H10 to recovery tool
The procedure depends on what version you have.
Below there is the procedure for 20 GB , on other models procedure is the same, but you must find the right download for your model.
For 20 GB :
TO RESTORE "SYSTEM FILES MISSING" LOCKED PLAYER
--- This applies ONLY to the 20 gig version of the H10! ---
--- This procedure formats your H10 so all data will be erased on the player! ---
1. Power off H10 - 20gig unit.
2. Insert staple or other small object into reset hole to press reset button.
3. Connect player to USB cable.
3. Hold down Select key (labeled "O" - right button on front of player) while also holding down power key until player boots.
4. Unit must display "Emergency Connection."
5. Unit will now appear as a drive under My Computer. Right click on drive, select Format. No need to change anything, just proceed.
6. Download H10_20GB_System.exe. It is a self-extracting archive. Double click on it and unzip to c:\iriver.
http://www.iriveramerica.com/downloa...0GB_System.exe
7. Locate iriver directory, double click. You will see H10. Double click once again; you will see System.
8. Right click on system, select "Send to" and choose the directory of the player.
from System Files Missing
If you have the 5 or 6 GB see iriver - H10 5/6 GB Series Support
Feb 24, 2009 | iRiver H10 MP3 Player
Iriver Troubles
Delete the playlist and try to re-add using windows Media Player - make sure EVERY song in the playlist is in the right format
Mar 31, 2008 | iRiver H10 MP3 Player
Iriver H10
Dear dedin1
You must try to do a soft reset to ur player, or try to format it, that should work surelly.
Dec 31, 2007 | iRiver H10 MP3 Player
hope this helps.
Mike.
Sep 21, 2007 | iRiver H10 MP3 Player
Iriver H10 saying system Files missing
Try doing a format via windows explorer. Right click on the drive and then format as fat32. Then unplug and open iriver plus. Reconnect. See if that works. Good luck!
Jun 29, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
85 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
