Question about ASUS P5S800-VM Socket 775 Motherboard - SIS 661FX Chipset - Onboard Audio, Video, SATA Raid, LAN - M... (ASUP5S800VM)
I bought this sis chipset p5s800-vm by ASUS computer running at 2.66GHz and has 1.5M memory and can't get some applications to actually accept this computer's onboard video controller and to top it off - i don't have any drivers at all for this motherboard! i am running this on Windows XP Pro, SP2
    President:
  • 2,679 Answers
Just go here and get the drivers.
Posted on Nov 03, 2010
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
P5S800-VM/S
The best you can fit is an AGP 8X type card. They are difficult to find now, so the prices of decent cards are going up. Your computer is about 3 generations behind, You would get better graphics performance by buying a new motherboard, CPU and memory bundle. It would be cheaper in the long run, as you could then upgrade the graphics card in the future and then upgrade the CPU as well. You can still keep the case and other computer peripherals you already use. But if you want an AGP card look on the Auction sites.
May 10, 2013 | ASUS P5S800-VM Motherboard
GRAPHICS CARD
http://uk.asus.com/Motherboards/Intel_Socket_775/P5S800VM/
I see it is the VM/S version, and not the Asus O.E.M. version above.
My thinking is the motherboard was made for a proprietary computer manufacturer.
Perhaps NEC or Packard Bell.
Using this line of reasoning, it is my contention that the graphics expansion slot is the same, and motherboard chipset; for the VM/S version, as well as the Asus OEM VM version.
Going further...............
Specifications:
Graphics Expansion slot -
AGP and 8X........AGP 8X
Motherboard Chipset:
SiS 661FX - Northbridge chip
SiS 964 - Southbridge chip
http://www.motherboards.org/mobot/chipsets_d/SiS/661FX+964/
So we know the motherboard will support an AGP 8X graphics card.
Another item you need to have knowledge of, is what is the Minimum power requirement; for the particular AGP 8X graphics card you are looking at......
Let's look at some examples,
(They are getting fewer, and fewer; as the graphics card technology has gone to PCI Express.
PCI Express has evolved to the PCI Express 3.0 technology now)
A) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=853908&CatId=2234
Scroll down to - Features
-> Minimum PSU Wattage requirement
(Ignore of you are aware;
PSU = Power Supply Unit
The Power Supply's used in personal computers are SMPS.
Switched-Mode Power Supply)
MINIMUM power wattage requirement for the above AGP 8X graphics card, is 250 Watts.
Something I would like to impart;
Back in the day Power Supply manufacturers 'fudged' the True, Actual maximum wattage rating.
Actual maximum wattage rating, was more like 60 to 70 percent of what was stated.
If we use a 250 Watt PSU from back in the day, as an example; actual maximum rated wattage would be 150 Watts, to 175 Watts.
[Simple equation(?);
250 divided by 10 = 25
25 times 6 = 150
25 times 7 = 175 ]
Point?
DO NOT under power a graphics card!
A) It will not work right, or at all.
B) It will burn;
The gold plated contact pins on the bottom of the graphics card.
The contact pins in the graphics expansion slot.
Takes a while usually, but when done you can use the motherboard for a Frisbee.
Here is a Power Supply Wattage Calculator,
http://extreme.outervision.com/psucalculatorlite.jsp
Takes about 2 seconds for the page to fully load.
Need guidance in using it post back in a Comment.
It is the 'Rule of Thumb', to have at least 10 percent more power, than what is required.
Easier on the Power Supply, as it doesn't have to strain to keep up.
I myself would recommend a 350 Watt power supply, at least.
One more thing if I may;
LOAD THE SOFTWARE FIRST!
Load all the software that comes with the graphics card.
It will be on the Installation disk that comes with it.
You will be loading the Drivers, and user interface.
For a graphics card utilizing the ATI (AMD) technology, you will be loading Drivers, and the Catalyst Control Center.
For a graphics card utilizing the Nvidia technology, you will be loading Drivers, and the Nvidia Control Panel.
AFTER doing so, THEN turn the computer off, FOLLOW Anti-Static Procedures, and Physically install the graphics card.
Why?
Because when a device is installed on a computer that has Windows on it, Windows will 'break it's neck', to find suitable, matching drivers.
If THE drivers are not already there, Windows will match up one of it's THOUSANDS of generic, one-size-fits-all drivers.
This = No
A Driver conflict can result........
Windows: "Which drivers do I use?
These or THESE?"
For additional questions please post in a Comment.
Or Reply, at the end of this solution.
Regards,
joecoolvette
1) SMPS;
http://en.wikipedia.org/wiki/Switched-mode_power_supply
2) AGP technology;
http://en.wikipedia.org/wiki/AGP
3) PCI Express technology;
http://en.wikipedia.org/wiki/PCI_Express
Wanna increase ram
Hello your mainboard supports:
2 x DIMM, Max. 2 GB, DDR RAM ,Non-ECC, Memory.
Here is the homepage:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=22&m=P5S800-VM&os=&hashedid=ZcyLktAZjt2bXqgs
The ram module/s can be bought online, or in a computershop, and cost around 80 to 100 dollars each.
Good luck
Feb 21, 2013 | ASUSTeK COMPUTER Asus P5s800-vm Rev. 1.01...
Please can Anyone help me i Av ASUS P5S800-VM Motherboard no Video display,i have try the reset but still,please any help
The ASUS P5S800-VM is an older board so its probable that the onboard graphics have died. The board supports AGP video cards which are still fairly easy to find and not very expensive at all. I always recommend TigerDirect for any computer parts, I've used them for 7 years and have never had a single problem. Here is a link for a decent video card your motherboard can use.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5274433&CatId=2234
If you search AGP video cards you will find plenty you can use. Having the onboard graphics repaired (if even possible) would cost more than the computer would be worth.
Oct 29, 2010 | ASUS P5S800-VM Motherboard
I have so fat
Here the Infos about your mainboard:
ASUS P5S800-VM Allgemein MPN: 90-MBL0K0-G0EAYZ, P5S800-VM
Produkttyp: Motherboard
Formfaktor: Mikro-ATX
Breite: 24.5 cm
Tiefe: 24.5 cm
Kompatible Prozessoren: Pentium 4, Celeron D
Prozessorsockel: LGA775 Socket
Chipsatz: SiS661FX / SiS964
Maximale Busgeschwindigkeit: 800 MHz
BIOS-Typ: AMI
Storage Controller: ATA-133, Serial ATA-150 (RAID)
Prozessor Installierte Anz. (max. unterstützte Geräte): 0 ( 1 )
Speicher Unterstützte RAM-Technologie: DDR SDRAM
Installierter RAM (Max.): 0 MB / 2 GB (Max)
Unterstützte RAM-Geschwindigkeit: PC2100, PC2700, PC3200
Video Grafik-Controller: SiS Mirage
Videospeicher: Shared Video Memory (UMA)
Audio Audioausgang: Soundkarte
Signalprozessor: SiS964
Audio Codec: Realtek ALC655
Soundmodus: 5.1 Channel Surround
Kompatibilität: AC '97
Telekommunikation / netzwerk Netzwerk: Netzwerkkarte - Ethernet, Fast Ethernet
Besonderheiten BIOS-Funktionen: Wiederherstellung nach Stromausfall (Wiederaufnahme bei Verlust der Wechselspannung), DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash, Hyper-Threading-Technologie, RAID-Unterstützung, DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash
Sleep / Wake up: Wake-On-LAN (WOL), Wake on Ring (WOR)
Hardwarefeatures: ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2, Jack Retasking, ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2
Produktbeschreibung des Herstellers Das P5S800-VM unterstützt die neuesten Intel Pentium 4 LGA775 Prozessoren. Mit 800Mhz FSB, 1MB L2 Cache, Hyper-Threading Technologie und Spitzenleistungen von 3.6GHz und mehr ist der LGA775 Pentium 4 einer der schnellsten Desktop Prozessoren, die es zur Zeit gibt.
Dec 31, 2008 | ASUS P5S800-VM Motherboard
No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Oct 01, 2007 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Socket 775 Motherboard - SIS 661FX Chipset - Onboard Audio, Video, SATA Raid, LAN - M... (ASUP5S800VM) Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
