Question about GE Refrigerators
My refrigerator (PSC25SGSSS) on the refrigerator side is heating up. We can't make it cool down. It is currently showing 112 degrees. The freezer side is OK. We've cleaned out everything from the refrigerator side. No technician is available until Monday the 12th. 'HOW DO WE MAKE THIS THING STOP HEATING UP???
  • wjohn1938 Aug 15, 2008
    I was away for 3 days. Upon return the refrigerator was 140 degrees, the freezer 18 degrees. Had a technician out and he did not have a solution. Another I talked to suggested the mother board is defective. GE Profile PSI 23SGPAGS
A GE tech came out and solved the problem.
Thanks,
Ted
Posted on Jun 13, 2008
Do cooling vents ice over if water filter needs replaced
It's more likely that the automatic defrost system is defective, or the heating wire for the defrost drain. It's also possible that the temperature controls are set too low. Try zero degrees for the freezer and 38 degrees for the refrigerator side. If that works without problems you might put the freezer at minus two degrees and leave the refrigerator at 38.
Another possible fix is to put a longer heating wire in the drain.
May 31, 2014 | Samsung RS2630SH Side by Side Refrigerator
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
Refrigerator is not holding temperature. Currently at 50 degrees set a 7!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 15, 2011 | KitchenAid KSRP25FNSS Side by Side...
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
Freezer get up about 27 degrees and then start going back down to 0 degrees. Does it everyday.
Sounds like the defrost timer/control is sticking...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a GE refrigerator model number PSC25SG SA SS which has Problem that in every couple days the freezer and the refrigerator display panels display out of their setting ranges. For example, the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 24, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
Ge side by side tpx24biyaww freezer not cold enough.
hi there,
have check the current rating,this can determine if your freezer is under charge,use a clamp ammeter hook it up on common line of compressor,set ampere on tester to 50 amper so you can read clearly,compare this on rated current on manuals or theres a description tag on backside of your freezer look for rated amperes .this should be done by aircon / ref technician if you can't do this,have check also the leak , have a nice day don't forget to rate me,thank's
May 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is frosted in back Refrigerator is warm
The problem is the defrost system located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Mar 29, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
