Question about Sennheiser RS130 Headset
My Rs-130 headphones do not turn on, and there is no sound indicating that they do not work. I have changed the rechargable batteries with brand-new (non-rechargable) ones batteries. I have also checked that the batteries have been inserted correctly. No success however and still no sound from the headset. The transmitter appears to be working fine because the lights on the unit work ok. It seems as if the headset itself is completely dead.
3 Suggested Answers
SOURCE: RS 130 not working?
I am having the same problem...i tried resetting it as well...no luck
Posted on Aug 26, 2008
Fixe_You
  • 1800 Answers
SOURCE: How do you get a sennheiser RS 130 headset to work in a computer?
i told u so kayla. a sound card upgrade is necessary so the connection would work.
plz rate!
Posted on Mar 07, 2009
How do I get sound to my Sennheiser RS120 wireless headphones when it shows as working properly?
Dirty volume control on headphones. Try moving the volume control back and forth several times to clean off the contacts.
Dec 14, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
The headphone does not turn on anymore
I have got exactly the same problem with mine. Mine are RS140.
So if there is anybody that can help with this I would be very happy to find out what the problem is (as only used them twice)
Apr 26, 2010 | Sennheiser RS 130 Consumer Headphones
Have a TR130. Unit is 5 plus years old. Original batteies
Being over 5 years, I know these batteries don't last that long typically. But even if you change the battery this problem still occurs, I see:
http://www.fixya.com/support/t2397503-sennheiser_tr130_headphones_hdr130
Get your multimeter and try measuring the battery voltage when they were out and when they were in with the thing turned on. If the volts don't change more than millivots (small), then it's not the batteries.
Check the REC OUT to make sure it's not set to PHONO it should be on SOURCE. You should be able to hear a little bit of static if it's normal.
Did you try changing channels? I thought the channel switch was a rotating knob, but it's not -- it's a push button that toggles from 1 to 2 to 3, and takes a few seconds to auto-fine tune on the frequency. Try changing the frequency and waiting five to ten seconds between button pushes to see what happens.
You really should get some new batteries if the above information doesn't resolve it, new AAA rechargeable batteries should.
Jan 13, 2010 | Sennheiser HDR 130 Consumer Headphones
Headphones cut in and out - distorted sound
Dance_to_it -
I have had these great headphones over 15 years (I think!)
1. Are the batteries getting a full 8 hour charge?
2. Have you tried all 3 channel options?
3. Is there anything else close by that is an RF transmitter or receiver? If so, move the headphone base or other RF instrument away from each other.
4. If these are the original batteries you probably need new ones.
5. When purchasing new batteries I recommend original equipment Sennheiser BA151 batteries, not any other brand. I have tried 3 or 4 other brands, all with less than satisfying results. I have no affiliation with Sennheiser corp., just a consumer of their products (and Grado's for wired headphones)
-KWS
Aug 13, 2008 | Sennheiser RS 65 Consumer Headphones
Sennheiser TR136 Wireless Headphones Nothing Happens
I had a similar problem - after owning them for 4+ years, no sound we coming out, and no beeps -- nothing. The lights on the charger stand were on though.
I tried buying new rechargable AAA batteries and they were NIMH (nickel metalhydride?) and still didnt work. I borrowed a friend's pair of NICM (nickel cadmium?) AAA rechargables though and the problem was solved!
So, it would seem the some of the new chargable battery types might not work in older models of this unit (which is also called the RS 130 now in the US and Cdn web sites).
Hope this helps!
Mar 29, 2008 | Sennheiser HDR 120 Consumer Headphones
RS 130 not working?
Jan 13, 2008 | Sennheiser RS130 Headset
Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Jan 10, 2008 | Sennheiser HDR 130 Consumer Headphones
Replace the NiMh batteries. They might be bad. Could happen during power surges as you indicated you had. Let them charge up fully 14-18 hours as the book suggests.
Aug 25, 2007 | Sennheiser RS115 Wireless Headphones
Sennheiser RS130 Headset Logo
79 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Carlo Barzo
Carlo Barzo
Norman Worley
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
