Paper Jammed. I can not take out the cartridge
    Master:
  • 474 Answers
Need more info. I.E. model, brand.
Im asuming a printer.
try removing the cover and pulling the paper out, you may need pliers or tweezers to do so. Unplug it first. If its a small home printer it may not come apart easily, there made to last a year and **** out.
If its a large netwrok printer it should have access hatches on the front and back, open these and check for paper and debre.
Posted on Jun 12, 2008
How do i sort out my jammed paper for my samsung multifunction xpress laser printer m2070w please
pull out the toner cartridges and see if paper wedged under the cartridges. Pull out the drum unit see if paper wedged under it.
Check back of printer . may may a cover where paper turns around may be jammed in this location also. check paper tray pull it out see if paper jammed at paper pickup point.
Check printer user manual for clues on how to clear paper jams
page 91
http://downloadcenter.samsung.com/content/UM/201512/20151210113455258/EN/english.pdf
Jul 03, 2016 | Samsung Office Equipment & Supplies
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 21, 2014 | Epson LX-300+ II Matrix Printer
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
Important:
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
I have a piece of paper stuck in the top of my hp 1012 printer and I cannot get at the area where the paper is.
Follow these steps to remove jammed paper from the printer
1.Open the print cartridge door, and then remove the print cartridge.
NOTE:  Opening the print cartridge door and removing the print cartridge relieves tension on the product rollers, which prevents damage to the product and makes the removal of jammed pages easier.
Figure 1: Open the print cartridge door and remove the print cartridge
CAUTION:  To prevent damage to the print cartridge, cover it with a sheet of paper to minimize exposure to direct light.
2.With both hands, grasp the paper where it is most visible, including the middle, and then carefully pull the paper straight out of the product.
Figure 2: Remove the jammed paper
3.Look inside the product for any torn pieces of paper or labels, and then remove them.
4.If any jammed paper remains in the input tray or the output tray, grasp it with both hands and gently remove it.
5.Reinstall the print cartridge, and then close the print cartridge door.
Figure 3: Reinstall print cartridge and close print cartridge door
1.Press the Power switch to turn off the product.
2.Wait 30 seconds, and then press the Power switch to turn on the product.
Happy printing.
Regards,
Shrey
Jun 02, 2011 | Office Equipment & Supplies
PIXMA 450...Keep getting paper jam message and I can't see any paper bits anywhere. Trying to open the machine from the back to look inside. Have removed the 4 screws on the back and still can't remove...
Hi
The paper jammed can be found in the paper tray, remove the paper at the paper tray and inspect the roller for small pieces of paper jammed.
The paper can be found in the ink cartridge compartment, open the cartridge door and remove the ink cartridges, look for posibble paper jammer. Also once remove, check also the cartridge carrier if does not stuck up or jammed (cause this might me the problem). Turn off your printer and then move the cartridge head using your hand moving to the from right to left side and from left side to right side for 2-3 times. Move it gently.
Paper can be found in the rear access door if it is accessible. Inspect some paper jammed there.
Please let me know if you need more help
Mar 10, 2011 | Canon Pixma MP450 All-In-One InkJet...
I have a paper jam i cannot find on a kyrocea fs-1300d any suggestions how to find and correct this problem?
Hi
1. Paper jammed can be found in the paper tray. Just remove all the paper and inspect paper jammed from the feeder roller.
2. Paper jammed can be found in the toner cartridge compartment. Remove the toner cartridge and inspect for paper jammed.
3. Paper jammed can also be found in the rear door of the printer (back door of the print). Check if there is a back door and inspect for a paper jammed into the roller.
4. Paper jammed can be found in the toner cartridge itself. Check for teared paper inside the toner cartridge.
Mar 05, 2011 | Kyocera Fs-1300d Printer
A piece of paper jammed up. I took the paper out but the alarm keeps on saying "Carriage jammed"
Hi there !
Check again your printer and maybe there is still paper jammed inside. Turn off your printer. Open the door cartridge and remove the cartridge. Check for paper jammed. After that return the cartridge and turn on your printer. Sometimes there is paper jammed inside that printer. Just press the power off and turn it on to roll over any paper jammed inside. Turning off on your printer also make your computer refresh the memory of your printer paper jammed.
To make hard reset of your printer. Turn off your printer and remove the power cable to your printer, leave it for five minutes and connect the plug and turn it on again. That will refresh the memory of your printer.
I hope it helps you.
Jan 25, 2011 | HP Officejet 7310 All-In-One Printer
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Cartridge is jammed
I have a canon pixma 780. It was working fine then I had a paper jam and message "Cartridge jammed" I removed paper with no difficulty-piece was not torn.Now it will not print at all Paper feeds through but no printing in any colour
Mar 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Computers & Internet Logo
61 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
