Question about Kenmore Dryers
Kemore electric dyer
Blows cold doesn't get hot when i look for model number i find m83976519 or 86870100 or 68701 all these numbers are on the door
  • 5,911 Answers
Click on the following link for information on how to diagnose a dryer "No Heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Your correct model number is 110.86870100. Manufactured by Whirlpool. You can find replacement parts at searspartdirect.com. Just type in the model number I provided and follow the links on the next page. The heating circuit components are listed under the "Bulkhead Parts" heading. Use the helpful illustrations for easy part identification. Accessing your heater components are easy on this model dryer. All you have to do in UNPLUG the dryer and remove the back panel. The heating element, thermal cut-out and hi-limit thermostat will be on the right-hand side (facing from the rear). The blower fan assembly will be on the left hand side. Using the parts listing on the Sears website, the following components are suspect if it is a heating circuit problem:
Item 1 (part #279769) Thermal cut-out w/ Hi-limit thermostat - sold as a set and recommended to be replaced at the same time if one or the other is found to be defective.
Item 14 (part #4391960) Heating Element.
Read through the link I provided and follow the steps. Try to rule out the common sense things BEFORE assuming parts are defective. You may want pay particular attention the paragraph explaining proper vent ducting maintenance and installation. If you do not maintain the ducting properly the heating circuits will eventually fail again due to overheating.
Please post back if you have questions and/or require additional assistance. I hope you find this information helpful.
Posted on Jun 13, 2008
W6444
make this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 25, 2013 | Washing Machines
Bravo XL Dryer not blowing HOT air
Can you look inside the door and tell me the model number? Electric or Gas? Here are some model numbers.
ELECTRIC MODELS: MED6300TQ, MED6400TB, MED6400TQ
GAS MODELS: MGD6300TQ, MGD6400TB, MGD6400TQ Sea Breeze
Feb 28, 2013 | Maytag Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Dyer only blows cold air
U may have a blown thermostat or bad heating element.
Nov 14, 2011 | Dryers
I have a 2001 Ford Focus DOHC. Heater doesn't blow hot. Hot cold indicator switch clicks as i9t should when I turn indicator but it doesn't seem to change anything
Feel your heater hoses and see if they are getting hot..If so when your click from the switch ,,make sure the door is switching from hot to cold
Sep 16, 2011 | 2000 Ford Focus
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
I plug my electric dryer directly into the fuse box my dryer is a 220 dyer works but is not blowing hot air,. it blowes cool air what can possibly be wrong with a dryer ....because it usedto work at a...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 09, 2010 | Kenmore 62602 Electric Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryers Logo
175 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
