Question about Dryers
I have an 8 yr old Kenmore 90 Series gas dryer, #11074932201. Yesterday it began to not dry the clothes..only cool air. I removed and disassembled the vent assy housing (as well as filter) and cleaned it thouroughly. Quite a bit of lint removed. Reinstalled and tested by leaving door open, but pushing switch in door casing to activate the operation cycle and it blows hot air. Today I put a load of laundry in to dry and after one hour the clothes were still cool and damp. Tested thermal fuse for continuity with ohms meter and all is ok. Tested 2 themostat solenoids for continuity with ohms meter and all is ok. I keep reading about an igniter. Is that the posible cause? Thanks in advance for your response!
  • mikeenany Nov 03, 2010
    I need to know if there is a diagram anywhere that I can view to inspect the parts that you've mentioned?
    Also, underneath the white thermal fuse is a sensor?? that has 2 purple wires, a red wire and a red/white wire. I disconnected the red and red/white wires from the sensor?> and added a jumper wire between the two to bypass the sensor?> I then plugged in the dryer and ran it for about 5 minutes. At the start, I had heat immediately and I can see the glow of flames behind the protective shield. After about 5 minutes the air flow out the dryer vent began to sputter and the glow of flames went out and then cooler air was being dispensed.
    I then disconnected the jumper wire and plugged the red and red/white wires back onto the sensor?>
    Once I started the dryer again I had heat immediately and could see the glow of flames behind the protective shield. Once again, after about 5 minutes the air flow began to sputter and the glow of flames went out and then cooler air was dispensed. So it appears that this part (sensor or whatever it is called) appears to work the same whether it is connected or not
    I hope that info helps!
    Thanks again, Mike
  • mikeenany Nov 04, 2010
    I installed 2 new gas valve solenoids today, following the step-by-step procedure that you provided. Once completed I did a load of laundry and everything works great!
    Thank you for your technical support and expertise. I appreciate your time & effort.
    - Mike
    President:
  • 1,554 Answers
The thermal fuse and the cycling thermostat on the blower housing and the thermal cut-off and the high-limit thermostat on the box must have continuity. If those parts have continuity, the problem can be with the igniter, flame/radiant sensor, or the gas valve solenoids sitting on top of the gas valves. Check the igniter if it is glowing red hot when the dryer is turned on. If yes, then the gas valve solenoids are not working. Test the coils for continuity and replace both of them if one or both of them are found open. The igniter, which is made of a very fragile material, must be broken if it doesn't glow red hot. Inspect the igniter for such obvious sign of physical damage.
Posted on Nov 03, 2010
  • Jahn27
    Jahn27 Nov 03, 2010
    All of the parts mentioned above are therefore working properly except for the gas valve solenoids. The solenoids are working perfectly when cool but are weak and eventually fail when it get hot as manifested by the flame and therefore the heat going out after 5 minutes which is enough to heat up the coils. The only viable solution is replacing both coils.
    Disconnect power then pull the lint trap out and remove the screws under it.
    Pry the top cover as shown then raise it to the rear of the dryer.
    Disconnect the door switch and remove
    the screws attaching the front panel to the cabinet then lift up and
    remove the panel. Disconnect the wires from the coils and remove the screw that secures the coils holding bracket then slide the coils out.
    Slide the new coils in and reconnect the wires then secure the coils holding bracket back in place.
    Reinstall the front panel back into position by following the removal steps in reverse order. Reconnect the door switch then rotate the top panel back into position and push it down to snap the clips and secure the top panel to the font panel. Put the screws back into the lint door opening and reconnect power to complete the repair.
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore 90 series gas dryer will not dry clothes
Possible blown fuse, cracked igniter,gas turned off
Feb 12, 2013 | Kenmore Dryers
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
How to use my kenmore gas dryer 90 series and the heat fire comes on but does not stay on for too long and it does not dry the clothes. what is wrong.
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 23, 2009 | Kenmore Dryers
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Nov 04, 2009 | Kenmore Dryers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
205 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
