Question about WindCrest 35 in. CTG365D Stainless Steel Gas Cooktop
Gas cooktops I am planning to buy gas cooktop with the highest btu. The cooktop has to be down draft. I have to decide between whirlpool gls 3665 RS or windcrest ctg 365 d. I can use some advice. thanks
Windcrest all the way!
Posted on Jul 03, 2008
  • 161 Answers
Go for ease of cleaning. Avoid any light colors expecially the grates. White cooktop, light grey grates, AWFUL I replaced it within 6 months. Stainless or black is fine, very easy to clean. Make sure the drip area can contain a spill . Another importent thing, If you can see it connected, turn the flame down as much as possible and see if it stays lit. Pusling and relighting is a plus some higher end units do this. It is very hard to get a true low flame on a high BTU unit. Another big plus. See if the grates are arranged so you can slide a pan over without lifting. This seems a minor point but what a luxury.
Posted on Jul 01, 2008
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
    You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
    Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
    My kitchenaid gas stove continues to try to ignite making popping sounds
    Here You can see how to disassemble Kitchenaid cooktop. I replaced everything on this one, since I knew its a big job, decided to do everything at once. Problem is - cooktop is dead, no spark to any burner. I hope it helps! Thanks! How To Repair Whirlpool KitchenAid Stove Cooktop HD 1080
    Apr 24, 2010 | KitchenAid 31 in. KGCS105 Gas Cooktop
    My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
    Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
    Cooktop Range Stove spark ignition does not work
    Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
    Whirlpool gas cooktop will only spark on left front burner
    i made this video to help you troubleshoot kitchenaid and whirlpool cooktops
    Apr 01, 2010 | Whirlpool GLT3615 Gas Cooktop
    Kitchen Aid KGCS105GSS08 conversion kit color code propane, I purchased the kit there are seven orifices four with different colors it does not indicate which color is for which BTU
    the conversion kit is also a number,check the no.from lowest no to the highest no.the small no is for small burner and the bigger no is for big burner...the other is for other burner.
    Jul 04, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
    Installing JED8230ADB Cooktop Grill with down-draft exhaust
    I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
    In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
    Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
    Check if there is a fuse for the device, check connections as well. keep me posted.
    Jun 26, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
    Jenn-Air JGD8130
    The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
    Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
    WindCrest 35 in. CTG365D Stainless Steel Gas Cooktop Logo
    124 people viewed this question
    Top WindCrest Cooktops Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a WindCrest Cooktop Expert? Answer questions, earn points and help others
