Try again exactly according to the operating instructions: 1. Switch off the appliance. 2. Clean and dry the metal contacts on the residual water drawer. 3. Switch the appliance on again and remedy the fault as follows: - Push the residual water drawer into the appliance and leave it there for at least 20 seconds. - Remove the residual water drawer again. Then empty and dry it. - After at least 20 seconds, push the drawer back into the appliance. The appliance is now ready for use and will continue the process started before the fault occurred. 4. Switch the appliance off and then back on again.
If the indicator light continues to flash, call Miele.
Have you cleaned it lately with vinager? Sometimes you have to run it through it to remove the deposited from hard water. It happens to coffee makes an all appliances that use water. Find your instructions an follow what is recommended. If you don't have them you can look them up online.
Remove power and make sure that there is water present without any air and also there is no dirt. Remove , flush and refill and see if the fault changes. There are a lot of complaints with customers not satisfied after investing a good sum and so if this is with/around warranty you can file a complaint as there is a possibility that the chamber is clogged- if there is brown coloured water coming out.
you have probably solved this by now but I just got the same model new switch on instructions as follows press and HOLD the POWER button for 3 seconds to switch the unit on once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds this will prime the steam pump and only has to be done once for each ironing session the pump noise will stop once it has been primed with water hope this helps if still needed if you need the user guide, let me know, I'll scan it for you Wendy
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
