Question about Samsung Pleomax Zirex UHD-12G 12 GB USB Hard Drive
Samsung Pleomax 12 GB hard drive, computer says "USB Device Not Recognized"
    Brigadier General:
  • 10,406 Answers
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
My Pleomax external hard drive stopped working on my MacBook (OS Maverick). It worked for one day and that was it. It flashes green and red when connected.
Probably not an issue with the MacBook but with the Pleomax drive. Be sure the drive is getting enough power to begin with. If it came with a 2 headed USB cable be sure to connect BOTH USB connectors to the Mac. You may also want to try the drive while your COMPUTER is plugged in and charging. Laptops and external drives don't always get along due to power differences and specifically laptops who do not want to waste their battery power on an external drive. If all else fails, try the drive on another computer just to make sure it is a drive problem and then contact the manufacturer for a repalcement drive.
Dec 11, 2013 | Samsung Pleomax 120GB External - USB 2.0,...
Samsung Pleomax Ultra-Portable UHD-12G - hard drive - 12 GB - Hi-Speed USB. I think the autorun was deleted off of this flash drive. The computer does not see it at all. There are no yellow x's under...
This could be an issue with assign the drive a letter:
1. Right Click on "My Computer" (might be called computer)
2. Left click on Manage
3. On the left click on "Disk Managment"
4. Check to see if the 12GB USB drive is showing up there if it is then right click on it and assign it a drive letter.
If the USB does not show up in "Drive Management" then try another USB port or another computer to test to see if the USB drive shows up.
Hope this helps
Mar 07, 2011 | Samsung Pleomax Zirex UHD-12G 12 GB USB...
Computer does not recognize Samsung Pleomax Ultra-Portable UHD-12G - hard drive - 12 GB - Hi-Speed USB
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps don
My computer says "USB device not recognized" when
You are likely missing the drivers. If you really need to get it open, plug it in, find the drive, right click and select explore. This MIGHT work; i'm not entirely sure.
Feb 09, 2011 | Western Digital WD Passport 250GB Portable...
I WANT TO REFORMAT MY PLEOMAX BECAUSE I NEED THE SPACE.
just run cmd and write fdisk follw instrucion you will get more space
Jul 18, 2009 | Samsung Pleomax Zirex UHD-12G 12 GB USB...
Samsung Pleomax SAM MD-205 driver?
It took me a lot of digging to try and find a driver download. You can try the UHD25-80GB driver (this is for Windows 98, but you can try to see if it fixes the problem): http://www.samsungpleomax.com/sup_03_01.asp?page=2&fcate=Driver+download&scate=Storage+Media&tcate=HDD&scateg=Storage%20Media&tcateg=HDD. Direct link to zip file: http://www.samsungpleomax.com/sup/cs/HDD-driver-2500-80GB%20DRIVER.zip
Also, specs indicate that you need USB 2.0 or 1.1. I had problems connecting via a 4-port hub (that was supposed to support USB 2.0) so ended up connecting directly via my computer USB ("Enhanced" = 2.0) slot, which seemed to work fine.
Apr 04, 2009 | Samsung Zirex Pleomax 80GB Portable Hard...
Pleomax problem
Try clicking on the icon in the taskbar and if it's like SanDisk flash drives there is a program you need to install from the Pleomax itself, that enables it and several tools as well. When you see that window, there will more than likely be an eject button as well.
Mar 16, 2008 | Samsung Pleomax Zirex UHD-8G USB Hard...
Not being recognized on any computer
The internal silicon chipset has been corrupted.
Did you try to use your folders within the the drive.If you did,this corrupts the deep set memory.
Unit is now U/S.Sorry
Jan 27, 2008 | Samsung Pleomax Zirex UHD-8G USB Hard...
Samsung Pleomax Zirex UHD-12G 12 GB USB Hard Drive Logo
178 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
