Question about RCA WHP140 Consumer Headphones
The headphones work perfectly but the ear pads are falling apart. can i get replacement ear pads???
  • RCA Master
  • 5,615 Answers
I need help to fix my headphones
In most cases the wires are small and you have to replace the whole cord that goes from the jack to the headphone. If you take the ear cup pad off, look for screws to remove the cover over the speaker. If there are no screws then it is a press on or a sealed ear cup. You will ruin it trying to get it apart. If you do get it apart, you should see where the cable comes in the earcup and fastens to the speaker and the to the other cable that goes to the other ear cup. You will need to use a soldering iron to change the cables. Pay attention to the colors of the wires and where they connect or you will have a phase issue.
Jun 27, 2014 | Audio Players & Recorders
EAR CUSHION
Sony parts suppliers sell replacement ear pads. Part no 2-320-280-01 about US$16 each (not pair).
Old ear pads slip off - pull gently to stretch the part that sits in the groove of the headphones until one side slides out.
The creative sewer can remanufacture new pads from thin soft leather by following the pattern of the old ones.
No cost fix is to scrape off the remaining peeling urethane leaving the soft fabric backing. Headphones will still work but the soft earpads should absorb high frequencies.
Sep 12, 2012 | Sony MDRXD400 Professional Headphones
Where do I find ear pads fo eh-710
Hi all,
For the few left who haven't tossed their headphones because of their disintegrating pad donuts, maybe I have a solution. Remove the pads and invert them so as to reveal a perfectly intact underside. Get out your hairdryer to heat them up and reapply the pads from the reverse side. Mine have been sitting in a box for nearly a decade and I finally discovered this solution. Hopefully it works for you, because it's a shame to toss such great quality headphones. Good luck!
Dec 03, 2011 | EarHugger EH-710 Professional Headphones
Ear pads falling apart
Please follow the proper instructions below
Ear cushion reattachment
If the ear cushions come off your headphones,
reattach them as follows:
1. Fit the mounting flange inside the rim of the ear cup.
2. Make sure it attaches smoothly and uniformly within the entire ear cup. (Do not remove the ear cup lining material).
Ear cushions may need to be replaced due to normal wear and tear. To order replacement ear cushions, call 1-888-865-2700.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Bose 41213 Headphones
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
Replacement foam for Beyerdynamic DT 531 Consumer Headphones
I have the same problem with a pair of Fostex Headphones. I have taken them apart and I have removed the rubber type ring that the foam fits over.
I am going to order a cheap pair of thin foam Headphone ear covers from Ebay. (They are available in various sizes) and stick the foam to the ring and follow that
by sticking the ring back in. Should work if the foam is thin enough. What do you think?
Eddie
Nov 27, 2008 | Beyerdynamic DT 531 Consumer Headphones
Ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
Nov 12, 2008 | Sony MDR-V6 Professional Headphones
RCA WHP140 Consumer Headphones Logo
748 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
