Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
My harddrive wont show on my computer and when i turn it on it beeps continously, what could i do to get it to show on my computer of just fix it completely
    Brigadier General:
  • 10,406 Answers
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
Western Digital Harddrives // Win Vista two separate harddrives with same problem - once plugged in, lights on harddrives turn on, computer beeps but, doesnt recognize the hard drive. WinVista...
Uninstall the WD drivers, then, leaving the WD drives attached to the computer, reboot the computer.
Here is something else to try: Driver Booster by Iobit.
11 Free Programs That Will Help Update Drivers in Windows
And take a look at the software for your drives at the Western Digital site.
Aug 10, 2017 | Olympus Computers & Internet
Not sure if it is MB or CPU when i try to turn on computer the only thing that happens is i hear a beeping sound. beep...beep...beep... continually. it wont go to the post, nada. the fans run and i have...
Continous beeps usually mean the motherboard or the power supply, Try another power supply first and see if it will boot, if not the motherboard is faulty, if the prossesor was faulty you would no beeps the fans would run but nothing on the screen. hope this helps.
Aug 24, 2010 | Computers & Internet
Why does it continously beep? Why is it starting up by itself? Even after turning off? When you open the door it shows a light on rinse, when it was set on normal.
Not sure if your dishwasher problem has been fixed yet.
The continous beep and the rinse light on means the flood switch in your single drawer built in dishwasher has come on.
There is water leak inside the housing under the drawer. Turn the power off at the mains breaker and pull the drawer out as much as possible. Get a few towels and dry out the bottom of the dishwasher under the drawer. Use hair dryer if well.
Turn the power back on and see if the problem disappears. Sometime too much foam in detergent can also cause it but mostly it can be due to drain hose been kinked or gasket leaking.
Post a comment to let me know what you find.
May 02, 2010 | Fisher and Paykel 24 in. DS603H I Built-In...
When starting up the computer, I get 5 short beeps then continous
These beeps seem to show that your system did not detect any RAM (memory) modules connected to it. Please check.
  1. Open the CPU case (turn the PC off first)
  2. Remove the RAMs from the slot.
  3. Turn ON your computer without the RAMs installed. Then observe if it gives the same beeps. If it is the same, then the RAMs might fail to register.
  4. Try to plug in carefully the RAMs in place. If you have 2 RAM modules, try to test 1 RAM at a time to see if the combination of the 2 mess up your system.
Feb 13, 2010 | Computers & Internet
IT TURNS ON BUT SHUTS RIGHT BACK OFF CAN SOME HELP ME FIX MY PLAYSTATION3
Try removing the harddrive, and then turning it on..
If it will stay on without the hardrive then the hardrive has gone bad..
If it still wont stay on please reply to the post with any beeping noises it is making,or any other error conditions it shows...
Oct 31, 2009 | Sony Playstation 3 (PS3) Console
Beeps continously and has orange color
The beeps you hear are BIOS Beep Codes. Sort of a 'Morse Code', if you will. So many short beeps, or so may long beeps, or a combination of short, and long beeps, making up a code.
This is the computers way of telling you something is wrong, and an area to start looking in to find the problem.
BIOS = Basic Input/Output System. A small, (Usually 64MB in size) program that is on the BIOS chip. (Chip is a slang term for Integrated Circuit. The BIOS 'chip' is soldered to your motherboard.
http://en.wikipedia.org/wiki/BIOS )
How to read that BIOS Beep Code? This becomes a little more difficult, as there are two main BIOS program makers, and every series of computers may have a different version of that program. (Award and AMI. Award and Phoenix merged)
HOWEVER, listen carefully to those beeps. Listen for a continuous series of beeps, then a pause, then the series of beeps again.
Compare what you hear to this chart,
http://www.pchell.com/hardware/beepcodes.shtml
A common problem is that ram memory stick/s may have become loose, or the ram stick is defective. (Ram 'stick' is slang for ram module)
Try re-seating your ram stick, or sticks if you have more than one.
The orange light means your harddrive isn't active. That lamp, (light), that you see is the Harddrive Activity Lamp. Red means it's working, (Active), Orange means it isn't.
If you have a ram memory problem, (Ram stick/s), your computer isn't going to work, which means the harddrive won't be working.
Aug 06, 2009 | HP Compaq dc5100 Small Form Factor PC...
Getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
I switch my computer on and it plays a continous beep
if you want to find out what the beeps mean this page will tell you. If you cannot figure out how to fix it still i will be happy to help
http://www.computerhope.com/beep.htm
Jan 08, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
89 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
