Question about Troy Garden
Change blades on a lawn tractor pony? troy built
  • 37 Answers
Just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Posted on Nov 10, 2010
Is there a service repair manual available for the pony lawn tractor?
http://www.mymowerparts.com/pdf/Troy-Bilt-Troy-Built-Service-Repair-Manuals/
Oct 09, 2014 | Garden
Two blade mower deck, bearing bad on right can I run with only 1 blade
if you do, you would have to figure out the new belt length and routing. It would be easier to just change the spindle. You could probably just replace the bearing but my guess would be the whole assembly would be about the same price on amazon. If you do change the whole assembly, make sure and keep your old spindle just in case you hit something and the caseing breaks.
Jul 01, 2014 | Craftsman 42" Briggs Stratton 20 hp Gas...
What caused Troy built Tractor (pony) stopped running sudden
Replace HT leads with silicone ones, u shud not get any shock from old ones un less they are breaking down,unless they are leaking , u shud now get a big blue spark if not then also replace coil hope this helps
Apr 26, 2014 | Troy Garden
How can I get a manual or schematic for Troy Buily Pony Lawn Tractor
i don't have a manual but it sounds like the center pulley is stuck the center of the center pulley should move and change sizes with tension
Jun 12, 2012 | Troy Garden
My 2008 Troy Bilt Pony lawn tractor will not engage in iether forward or reverse. No clear reason just stopped working. The transmission locks up and the tract or will not start either (probably because it...
Make sure the brake pedal is fully depressing. Check the linkages for the forward / reverse and brake pedal. Check for grass build up causing the linkages to bind.
Nov 26, 2017 | Garden
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    I have a Troy Built lawn tractor, after removing
    Clearly the cable either broke, came loose.
    Aug 22, 2009 | Garden
    Troy Built Ride-on, stalls when blade is engaged.
    You may have a short in one of your safety switches. There is usually one on the seat that shuts it off if you try to get up and one on reverse if you try to back it up. I would look there to see if somehow they are grounding out
    If you can get it where you can grab the blades, check and see if they float easy. You could have a seized bearing on one of your blades that is stalling out the motor as well.
    Hope this helps
    Aug 20, 2009 | Garden
    Garden Logo
    146 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    DROPNDEAL
    DROPNDEAL
    Wade Mobley
    Wade Mobley
    Are you a Troy Garden Expert? Answer questions, earn points and help others
