Heating & Cooling Logo
Anonymous Posted on Nov 02, 2010
My condensor fan motor has gone out. It is an Emerson 4259 model. I can not find another the exact same. Can I replace with anything? As long as the shaft is the same and diameter of motor is same?
  • Anonymous Nov 03, 2010
    very helpful
    the one I have is a 1.1 amp,,, all I see are 1.6... is that okay?
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Nov 02, 2010
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
611844
Points
4917
You can use any motor as long as it has the same ratings (voltage, amperes, and horsepower), shaft diameter so the fan blade fits in, and the motor size so it fits into the housing. Make sure that power is disconnected before attempting the repair.
    That is still okay. Just don't use lower ampere rated motor.
I REPLACE CONDENSOR FAN ON A LENNOX BUT THE FAN IS OVER HEATTING AND STOPS& COOLS DOWN AND RUNS
Did you replace the fan blade or the fan motor? If you replaced the fan blade, is it exactly the same blade as the old one? If it has more blades, or wider blades, or if the blades are at a different pitch than the original, it is capable of moving a greater amount of air, but the old fan motor is not big enough in Horsepower to do the extra work. Thus, you should change the blade again to one that is exactly the same as the old one. If it is a window unit, you could try running the fan on a lower speed and it might work.If you replaced the fan motor, you must check to make sure that the new motor is exactly the same as the old one. You also could have it wired wrong, so you must check that also.
It does not make ice compressor and condensor seem
Sounds like your fan has gone bad. That would cause no airflow, resulting in no heat transfer and overheating.
That means it would not cool properl;y and would overheat.
Check for voltage going to the fan motor. If you have voltage there, but no fan operation, replace the fan motor.
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
2helpful
2answers
Replacing old 3 wire condensor fan motor with new 4 wire
the new one needs its own capacitor 5 to 7.5 uf hook to the 2 brown wires
2helpful
2answers
Refrigerator side walls are hot
these heaters in the wall come on when the house is hot to protect the fridge .there is a energy switch in the fridge that says ( if moisture appears) shut this off
1helpful
2answers
Samsung Frig
I had the same problem with my 2630. Unplugged the power cord and pulled the small panel off on the rear of the unit. The fan was working. I noticed a lot of dust built up on the condensor- the cooling fins were full of it. I took my small shop vac and cleaned off all that I could on the the surface of the condensor. Thought I'd try blowing it out in case I missed any in the inner part of the condensor. Reversed the hose on the shop vac so it would blow air and turned it on. Dust blew everywhere! Just vacuuming it out wasn't enough. No more problems with the heat- that seems to have cleaned it out so that the fan can now pull air across the condensor to properly cool it down. Hope this helps.
General Electric Refrigerator
Check the connection of the electrical harness to the fan motor. If it is fully connected and the motor still does not run replace the fan motor. The fan MUST operate at the same time as the compressor to properly cool the system. Spin the fan blade by hand with he power off. If it turns with any resistance the bearings are dry and in most cases the motor is replaced.
Top Heating & Cooling Experts
Paul Carew
john h
