Question about ASUS P4S533 Motherboard
Audio Error Message
On power up there is an audio message "System Failed - Memory Pack". The PC powers up, but no video. keyboard and no mouse.
  • Rfincel Jun 12, 2008
    Hi Bubba,
    The DDR333 memory could be the problem? I remember that with earlier motherboards, a PCI video card would not work if the memory failed. Am I correct?
  • 2,794 Answers
You have a failed component on your computer. Check your memory cards. If you have a spare video card, you should swap it out with that.
Posted on Jun 12, 2008
  • Tim Babcock
    Tim Babcock Jun 13, 2008
    You are correct.
Why does the sound no longer work on my PC?
Try downloading codex pack for you operating system as in are you using xp vista or win 7 or win 8
Jun 05, 2014 | Acer Aspire Z5700 PC Desktop
My desktop sounds like its on but the monitor, keyboard & mouse don't seem to also when I press the power on button after a little while it beeps about 4 times.
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Feb 02, 2013 | Dell Alienware Area-51 Gaming Desktop...
Shuts off when turning volume up. Error message
go to a computer store and tell them to rebot your computer that what i did it worked for me it should probly work for u
Dec 18, 2009 | Yamaha HTR-5760 Receiver
Sony pcv rx550 beep codes?
Hi , here are the codes. listen closely.
Error Message
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Check the CPU fan or BIOS settings for proper fan speed.
Phoenix BIOS beep codes
Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
Good Luck
Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
Keyboard failure at boot cannot use F2, F8 or F12 keys
watch it and bam solved
Aug 14, 2009 | Dell Dimension E521 PC Desktop
Ulead audio playing problem
By haneef_a on Aug 04, 2009
I can't play my project. I get this message:
Failed to use Direct Show video engine. Can not play back the audio stream: no audio
hardware is available' or the hardware is not responding. (13102:2:4)
Aug 04, 2009 | Ulead Videostudio 8 for PC
A display problem in my Acer desktop pc
techguru 2009: First thing disconnect all power. Remove all drives (hard drive, CD/DVD, Floppy). Then remove all PCI cards. Also slowly remove the Memory cards. You should only have the motherboard w/processor and the power supply connected, do not connect the monitor or mouse\keyboard. If you have a CMOS battery also remove it. Careful turn the power on, you should hear several beeps. That is letting you know that there is no memory installed. Turn power off disconnect power cord. Slowly install the memory cards, keyboard, mouse, monitor. If you have a pci video card install it now. Turn power on. you should see the bios loading then error message there is no disk or operating syste. turn power off and start connecting one device at a time so your bios can recognize it. This should let you know if you have faulty hardwareby isolating each install. If you still have problems let me know.
Jan 30, 2009 | AcerPower FV PC Desktop
On first power up, no video, no sound.
*********** board dead
hope ur smps &ram also ok ......
pl z check motherboard near pc service care.......
Jan 12, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Screen goes to sleep after "no signal" message
If you do not move the mouse or press any key on the keyboard it could be just going into video power save. Confirm it by moving the mouse or pressing a key on the keyboard. If the monitor comes back on, adjust the power settings in control panel and change the time for the "turn off display" to a more suitable setting.
Dec 31, 2008 | ViewSonic VA1930WM LCD Monitor
Unable to install Audio driver
have installed XP in Compaq Presario 707TU Laptop. I have configured audio as below. Install Microsoft UAA sp31994, then install High-definition audio driver sp33443. But I get the error message "Driver Installation Failed: Could not find the MEDIA device for this driver."...
Feb 12, 2008 | HP Compaq Presario v3000z Notebook
ASUS P4S533 Motherboard Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
