I have an LG WM12311FD washing machine which I have problems opening the door. I have read earlier answers but am unsure of which part needs replacing. Have looked at spare part web-site and don't know whether problem is caused by faulty door handle, door catch, or the door interlock system. If either of the first two I'm sure I could fix myself. Actually pulled the door apart yesterday just in case something loose and easilly fixed. Things looked OK, reassembled door but problem still exists. Will pull apart again today (once current load finished and I can get door open again) to actually compare components with web-site parts. If it is the door interlock system actually on the body of the machine is this something I could replace myself or should I call in a qualified person to sort out?
  • cmnicholls27 Nov 03, 2010
    Have managed to answer this myself after taking door apart again. Detected a fine split in the plastic at the catch end of the door handle. Have ordered a replacement, only £6.49 plus postage from UK website. Saved myself a tidy sum I think! In the meantime I will continue to open using pallette knife (didn't have any luck using shoe lace). Thank you FixYa!
Washer_tech
  • 164 Answers
SOURCE: Washing Machine Door will not open
these door locks usually work with solenoids (sp) if you unplug the machine
Posted on Jun 24, 2007
SOURCE: Ariston AWD 120 Door Handle is Loose
unplug it.
open the top lid.
reach down inside and feel a plastic sensor/release behind where the latch is.
towards the left center of that sensor, feel for a metallic manual release (you'll just feel the nub of it).
Push this in and to the side to manually release the door lock.
Call Ariston and complain about this common problem.
Posted on Nov 09, 2007
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
  • 1294 Answers
SOURCE: j845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 11, 2009
  • 1382 Answers
SOURCE: unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Posted on Jul 04, 2010
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
I have an LG front loader washer Model VM4270HVA and I want to know if I can reverse the door to swing open to the right as opposed to the left?
Some washing machines are available with the reversible doors, but only a few of them do (and they are expensive). Most times, you would have to order the machine with the specific door opening. You can probably check with LG support for a definite answer.
Jul 13, 2017 | LG Washing Machines
What is the issue with LG washer
LG WM2277HSW XL Front Load... Repair Questions - Fixya
www.fixya.com/.../p95436-lg_wm2277hsw_xl_front_load_stackable
Recent LG WM2277HSW XL Front Load Stackable Washing Machine questions, problems & answers. ... My frontloader washmachine will not turn on · LG ...
LG WM2277HSW XL Front Load Stackable Washing ... - Fixya
www.fixya.com/search/p95436-lg_wm2277hsw_xl_front_load.../open
LG WM2277HSW XL Front Load Stackable Washing Machine, open related issues. Get free ... Wait 5 secs after turning off door release should open. If this does not ... OE error message won't open door, won't spin out water What is filters & open it are my problemsDue to that I cann't ... Where is it sticking and how do I fix it?
LG Tromm WD 12270 RD washer and dryer 'LG ...
Dec 19, 2015 | LG WM2277HSW XL Front Load Stackable...
Lg wd8050fh
This could be the pump or valve. You need to take the bottom kick panel off under the door and see if you can tell where the water is leaking. Check the drain filter, there should be a removeable drain cap.
Mar 23, 2014 | Washing Machines
My aged invalid mother has a front loading LG washer dryer combo and has washed the same garment 3 times and after wash cycle or drying cycle can't seem to get the door to open to remove the clothes. What...
Hi I hope you solved this by now but I thought an answer might be useful if anyone else has the same question. I am not an expert just an owner of a LG WD-1412RD. It sounds like your mum is not aware this is just the normal safety cool down period following drying (as the stainless steel interior gets very hot during drying). The Door lock sign (small red light) is on, and the display shows Cd during this time, then it beeps and the door unlocks by itself. If you need to remove your laundry earlier than this, you can press the START/PAUSE button to end the cycle (it still takes a couple of minutes). This is covered on p 21 - 22 of the owners manual. which can be downloaded from the LG site. http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Nov 28, 2010 | LG WD-14124RD Front Load Washer / Dryer
From kim , we have a wm12311fd i put a wash in a
CHECK WATER PUMP FILTER IF OK CHANGE PUMP.... hope this works..01179512835
Dec 30, 2009 | LG Washing Machines
Service manual
http://us.lge.com/support/download/search.jhtml
This site should work for what you need. You will need your model number (located inside the front door, be sure you use model number, not serial number) to gain access.
Oct 31, 2008 | LG WM-2277HW Front Load Washer
Unit will not turn on at all. Power source definately works. Unsure if unit stopped during dry cycle or finished and never came back on, but clothes were dry, indicating it was finished with the wash...
Sounds like the problem is with the control board.  There is an internal fuse in the board but it is not replaceable.  You will need a qualified LG technician to service this unit.
Nov 03, 2006 | LG WD-3245 Front Load Washer / Dryer
My washing machine door wont open
Sorry for VERY late solution. I have an LG front loader machine and it has just broken. While surfing the internet, I found your blog. LG front loaders have a weak door handle, that breaks after a few years of operation. All the LG models seem to be the same. Replacement door handles are relatively inexpensive and readily available.To open your STUCK door, I would use a thin butter knife....slide the butter knife between the door and the frame of the machine until you hit the metal latch. Push the latch towards the centre of the machine and open the door.In the interim until you can get it fixed, this workaround method will work, enabling you to continue washing.Hopefully LG will make future models door handles out of cast, or something stronger!
Jul 29, 2006 | LG WD-1080FD Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
