Question about Canon 35-70mm f/3.5-4.5 FD Lens
Dropped camera lens and jammed the auto focus and it will not move
poolseman
  • 206 Answers
SOURCE: lens auto focus sometimes does not work.
First make sure contacts on lens are clean ( see enclosed pic #2 ) . If this does not solve the problem the ultrasonic motor may be faulty pic #1.( sometimes switching on but sometimes not , will have to be replaced , unless there is a bad connection between the motor and lens pc board )
Posted on Nov 26, 2007
t00nz
  • 4738 Answers
SOURCE: Lens error
The following blog outlines some simple repair options for a lens error. They won't work for all cases, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 28, 2007
SOURCE: Camera won't shoot with lens on Auto Focus
Talked to canon support, they suggested to send lense in for review/repair. They said it could be the motor, I think it was a gear problem based on the noises and jerkiness of the focusing action while in manual focus (manual focus gave out as well). Cost TBD - "would definately be more than $50. I shopped around and elected to buy a new lense rather than try to hassle with the repair, shipping, insurance, and the wait, etc. Besides, I have a deadline that I need the lense for, so repair at Canon really became a non-option. I think the cost would've been pretty much the same in the end as the new lense, since this wasn't one of the costlier of lenses to begin with.
Posted on Mar 20, 2008
pontelemon
  • 538 Answers
SOURCE: Auto focus does not appear to be working
Make sure AF switch is "ON" on the camera.
Still doesn't work?
Also, try another AF lens.
Posted on Apr 16, 2009
jeffpresnail
  • 42 Answers
SOURCE: dropped the lens, the focus ring won`t move
http://www.ejarm.com/photo/ef5018iidis/
Posted by another user, this is how to take it apart and fix it yourself. your exact problem is listed as fixable through this process. Good luck. Have the same lens and love it, even if it IS cheap.
Posted on Aug 11, 2009
My autofocus will not work all the time. when I want to zoom in for closeups it will be out of focus
This means that there is a alignment issue as the auto focus seems out of setting. This can be due to damage on the settings or a possible shift in the lens setting. This is due to a damage on the lens setting or a jammed motor drive. You will need some expertise to remove and check or reset the lens settings. If not take consensus as a false move can do more harm. need to remove the camera and the auto focus in the lens hood to test the motor drive, movement and action.
Oct 09, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
When power ON the screen displays"Lens Error!" & lens does not open.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 04, 2010 | Nikon Coolpix L1 Digital Camera
I own a casio exilim ex-z850. it has been showing a lens error, every time i try to take switch it on. the memory card is fine, i view the pictures. but the lens wont open up or anything. please reply...
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Sep 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
I have never been able to auto focus with my Nikon DX 18-70mm
Sure there's a cure! Auto focus on the 18-70 and a D70 has a few switches and menu settings that help to set it up. The switches are on the lens (I'm going to guess this is the one you're missing) and the side of the camera body. If you only have problems with this lens and other lenses auto focus fine, this is really the only thing that could make it not focus. The switch has two settings, M/A and M. It must be in M/A in order to auto focus. Older auto focus lenses don't have this switch.
The other switches and settings would result in auto focus not working with any lens you put on.
If you have problems with other lenses, or if the 18-70 is your only lens, drop a note here and I'll go into more detail on the other settings.
Jul 29, 2009 | Nikon D70s Digital Camera
Autofcous and manual focus do not work
excuse me if this is a dumb question but you wouldn't believe the things people do...., but in manual mode are you actually manually trying to move the lens? as manual mode means just that you take hold of the lens and turn it. If it wont turn it sounds like the lens is jammed and needs returning/repairing.
if taking hold of the lens and turning it works for manual mode, take the lens off and clean the gold contacts on both the camera and the lens with a pencil erasor this may bring the auto focus back to life, switch back to auto and try again, if not its most likely the lens but take the body to a canon store and try another lens just to double check the body is ok
drop me a line if i can be of further assistance
best of luck
Jun 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Focusing wont work after dropping
probably the lens inside is damaged or the mechanism which moves the lens is damaged. Focus works with a moving mechanism which moves the lens back and forth.
Oct 07, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon 35-70mm f/3.5-4.5 FD Lens Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
