It could be a piece that holds the battery in the compartment.
What happens when you plug it into an electrical outlet?
Same Problem
Mar 08, 2009
-   I have the same problem. I tried pushing in the buton/jumper where the battery door piece would normally push and turning the camera on at the same time - this seemed to work for a second, as the camera powered on, but I think I may have damaged the actuator button even more and now I can not get it to do it again.-   quistofer
Jan 22, 2009
-   no power after little white plastic piece between battery and SD card slot removed (broken off?). Appears to be a jumper of some sort. -   Guest
a white piece fell out from the spot next to the memory chip of my Nikon coolpix P4 camera, now the...
(More)
a white piece fell out from the spot next to the memory chip of my Nikon coolpix P4 camera, now the camera will not turn on, can you tell me what this piece is for and if my camera can be fixed, thanks
When power turned on , the message "lens error" appears in the lcd screen . I've tried...
(More)
When power turned on , the message "lens error" appears in the lcd screen . I've tried leaving the battery out for a few days , but the problem persists- Any ideas
