Question about Frigidaire ATF6000ES Front Load Washer
Door is leaking water, maching is 3 months old.
  • 1,531 Answers
Check the screws and make sure they are all tight on the door.also check the door seal and make sure that is is not torn or miss aligned.if you find nothing wrong then set it up for service as it is still under warranty.
Posted on Nov 02, 2010
Water appears in rear footwells, quite deep----about 3cms. We've had lots of rain bet we can't see where it's comiing in. all the window and door seals are good, and the boot seals. we've tested them...
OK ideas & to check:
is there water getting in through the rear doors as the inner door membrane is not watertight? if this is the case will need sealing.
Sunroof: if there is a sunroof check ducts are not blocked.
Tailgate lights: Is there water sloshing around inside any of the lights, as this may cause the water to breach their seal & run from boot under seat to footwell....
Is it just rear footwells or are the front wet too? if so check again ducts from sunroof as the hoses come out of the wheel arch. OR have you had new windscreen - poor fitting windscreen (even with the best intentions) causes it to leak. Or heater matrix (this will cause front wells to be wet & will run backwards: check your water levels in expansion tank, if it looses water could be faulty matrix. IF leak is rain water it tastes different to the water / antifreeze in tank...
Jan 31, 2014 | Air Intake Hose Citroen Xantia 2 1td Hump...
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Water leak from under refrigerator
Only two possible sources for a leak one is an ice maker, the other is defrost drain water. Either way it is only 9 months old and still under full warranty!! Call sears and have them come and look at it! I have seen a few of these units with cracked drain pans so be persistent if the tech cannot find a leak, have him pour some water into the pan to see if there is a crack.
good luck and save yourself some stress.. You have a warranty to cover this:)
Jun 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Zanussi DS17 slimline dishwasher is leaking from below the door at the front. The inside seals all seem to be fine, but the catchment moulding below the door (which is revealed at the front when the...
Have a look at the bottom spray arm and check the ends of the arm for splitting as this will cause the water to be directed at the door lower section and leak.Try taking arm out and run for a short while and see if it stops the leak.If still no good check that door is closing fully.
Apr 25, 2010 | Dishwashers
The door is always wet on the inside. I use the heated drying cycle. Glasses don't always come clean, are spotted, and the silverware is still wet. We have a water softner so that is not causing the...
1.you must fill your dispenser with jet dry.2. make swure water is hot going into maching from faucet then start machine. 3.add cascade soap. you will see a big difference. im a old bosch tech:) let me know what happens .
Feb 25, 2010 | Dishwashers
Water leaking from the door and front panel of my Duet washer
Check the rubber door seal, sounds like its split which is common after 2-3 years use.
You can find the general area of the leak by placing dry newspaper on a dry floor beneath the machine.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Water hose leaks at the washer connection
Did you change the rubber washers in the hose? or did you use the old ones there should be a rubber washer inside the front of the hose.
Jan 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore HE4T Washer Leak
there are 2 possible causes.
either
inlet valve leaking - turn water off and if water fill stops, it indicates valve leaking
valve being powered when machine off. this is very unlikely but to check, disconnect washer and see if problem stops
also, if drain is plumbed into a spigot on the sink trap, every time you empty the sink, some of the water will flow into the machine. to cure this, take the drain hose as high as possible under the sink in a swan neck
Oct 20, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
