Question about Fedders X Chassis A6X05F2B Air Conditioner
Beeping, random/constant changing of settings without touching
My ac runs great until randomly it will change back and forth from Auto, High, and Low. The beeping will slow down, speed up, just seems crazy. And very annoying. It seems as it wastes energy too from having to speed up and slow down. Very screwy.
    New Friend:
    Problem Solver:
  • 5 Answers
Mine did this too. I had to clean the control panel and make sure it is dry. The buttons were shorting out due to high humidity.
Posted on May 22, 2016
Fan motor run for five minute then get hot and shut down
Posted on Jun 14, 2008
Motherboard beeps once randomly while pc is running, idk what could possibly be wrong though... Can anybody help me?
Possibly some type of temperature alarm either from your motherboard or perhaps your video card.
Feb 05, 2014 | Dell Dimension C521 PC Desktop
Air condition
Depends on what the problem is. Could be low on freon, or the low or high pressure switch could be failing.
Could be a relay or the ac clutch too.
Jul 03, 2012 | 1998 Chevrolet Malibu
I got the samsung intensity phone, and it recently started to push random buttons by itself, scroll through my contacts, type random letters on my text screen, change its settings from vibrate, to beep, to...
seems like a an electrostatic problem. remove the battery and let it stay for some time. touch the battery terminals with a metallic object but not short circuiting. replace the battery and switch on.
Jul 01, 2011 | Cell Phones
Dryer randomly beeps, like morse code and changes ...
sounds like a stuck or shorted membrane switch.
which would require replacing the console. if you can access the tech guide in the control panel you can do a membrane switch test and other diagnostics.
May 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Cycles randomly change electronic panel seems to
I am having the same issue. It randomly cycles back and forth between cycles and never shuts off on it self. Before I go replacing parts I hope to get some advice what I should try first. Please help.
Nov 14, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
My maytag m6x06f2a-f window AC wont stop beeping
We had the same problem and changed the setting to auto and the unit seems to be working properly now. Not sure if this solves the problem, but for the past 1/2 hour the unit has stopped jumping between 00 and the temp we set.
Jun 07, 2008 | Maytag M6X06F2A Air Conditioner
Sb-600 not beeping, images completely black (underexposed)
Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
Apr 04, 2017 | Nikon Speedlight SB-600 TTL Flash
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Fedders X Chassis A6X05F2B Air Conditioner Logo
476 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
