Question about Microwave Ovens
How do I fit a Programme Module to my Bosch Exxcel Multi Progamme SGS45E02GB45 dishwasher
  • Sylvester O Neill Nov 06, 2010
    My problem is with a Bosch dishwasher not a micro wave. I have now resolved the problem on Wednesday without this information. Thank you.
  • Microwave Ovens Master
  • 19,396 Answers
Hi.
You will have to undo the screws that hold the inside door panel. There are about 20 torx screws holding the panel.
Once you undo the screws you will gain free access to the control panel, held by a couple of internal screws. Remove connectors and remove panel.
Disconnect power cord or trip circuit breaker before starting operations.
Regards.
Ginko.
Posted on Nov 03, 2010
  • Ginko
    Ginko Nov 06, 2010
    Re:"My problem is with a Bosch dishwasher not a micro wave. I have now
    I know, the information I gave was for your Bosch dishwasher, a microwave door is not held by 20 torx screws, that was my lastcomment:
    "You will have to undo the screws that hold the inside door panel. There are about 20 torx screws holding the panel.
    Once
    Disconnect power cord or trip circuit breaker before starting operations."
    Regards.
    Ginko.
Bosch HMT9656GB Plate not turning
THE TURNTABLE MOTOR HAS FAILED its easy to fix and doesnt involve going near high voltages remove microwave and flip it onto its roof a metal panel at the bottom covers it up if its never been removed before you will need to cut out strips holding plate in place. this reveals motor held in with 2 screws replace motor a cheap, part reverse fitting it should now work dont forget to fit drive dog and turntable glass before testing.
Nov 13, 2016 | Bosch HMT9656GB Microwave Oven
I have a Bosch built in microwave, HMT35M653B but it went dead today. How can I get a repair manual for HMT35M653B?
Hello and welcome new user of fixya! I found a link to the bosch support page: Bosch Home Appliances Customer Service Support Repair Parts. Try giving them a call or a shooting them an email. Best of luck!
-Mr. W
Feb 25, 2015 | Bosch HMT35M653B Exxcel Stainless Steel...
Bosch Oven Manual HBC86Q650I need a manual for the above oven/microwave
go to www. fitness.manualsonline.com or www. retrevo.com and download for free.
God bless you
Jul 09, 2013 | Microwave Ovens
Bosch microwave bulb
If there's no obvious cover or customer-accessible socket (and the owner's manual doesn't cover it), the manufacturer would prefer so.
It means that the whole outer cover or other panels would have to be removed to access the bulb or bulb assembly. In a bulb assembly, both the socket and bulb are replaced as one unit.
Jun 06, 2013 | Bosch HMT9626GB Microwave Oven
We have a bosch dishwasher that doesnt seem to be emptying?
You should pull the unit out of the cavity and check the inlet to the drain pump. Sometimes a label or something will get sucked into the inlet and block it. If you don't find a blockage then either your drain pump is bad or the water level sensor is bad.
Aug 17, 2011 | Microwave Ovens
The dishwasher will not drain completely
This video will explain what is wrong and how to fix it.
Bosch Dishwasher Repair Video
Feb 22, 2011 | Microwave Ovens
I have a creda europa solar plus double oven and want to replace it with a BOSCH HBM56B550B will the power supply I have be enough for the Bosch?
What you must do is calculate the total power required by the Bosch cooker. Convert it into Amperes and copper cable is roughly 10 Amperes per 1.50mm cable. What size cable feeds you cooker at present? Or
Is the maximum power calculated for the old cooker the same or more than the new cooker. If it is and the old cooker was installed by a qualified electrician observing local electricity codes, no problem get it fitted, if not consult a qualified electrician.
Jan 01, 2011 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
