Cannon S330 Printer was operating correctly, print cartridges required new. cartridges changed, will not print, after a time then would print black only, after more time colour began to print for several pages, then only black. returned cartridges for new but same problem. black printed for a while but no colour, now will not print black except for a few letters. all maintenance functions have been tried?
  • 385 Answers
Sounds like your print head may be faulty. If you can, get it replaced. This is caused by using recycled cartidges or faulty ink cartridge.
Posted on Jun 12, 2008
I got mixed cannon cyan ink and magenta ink together In cannon G1000 printer
Until you get the mix up all out you will never get correct color rendition. If you have some empty cartridges you can try filling them with cleaner and running their contents through the print head until output is perfectly clear. Then use new cartridges with the correct inks and ..........................
A real PIA operation but do able if patient.
Sep 20, 2017 | Cannon Office Equipment & Supplies
Cannon mp495
The printer will detect if there is any cartridges that has run out of ink and will not print until the empty ink cartridges have been replaced.
Jun 27, 2012 | Canon PIXMA MP495 InkJet Printer
I have just changed the black ink cartridge for my printer and every time it asks me to align the cartridges, it only works when I have the black one in there but doesn't work when they're both in...
  • Your model requires both cartridges at all times. Empty cartridge needs to be replaced to continue printing - this includes the color cartridge for black only jobs.
  • Make sure you are inserting the correct version of cartridges for your model. (32/34 black & 33/35 color).
  • Try to re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
Oct 21, 2011 | Lexmark X8350 All-In-One InkJet Printer
My printer will no longer print in black s520
if it is a new black ink cartridge and the printer still wont print black start by:
A: Simply making sure the settings are ok. To do this, go to file>print. When the printer box shows up. click properties.
From there, you will be able to see color settings. (ex. black, grayscale, full color.) Try switching to black or "use black cartridge only.
B. If "a" does not work for you, the print head which hold the ink cartridge is clogged or no longer working. Through the cannon window on the printer, try running a print head cleaning or any maintenance program.
If there's still no black, the print head has seen better days and needs replacing. Most of the time it is more effective to get a new printer.
May 22, 2011 | Canon Office Equipment & Supplies
Cannon Pixma 610 will not print with the magenta ink. I have used the cleaning utility close to 30 times and still nothing. Changing the cartridge did not help either. Any ideas?
When you said you used the cleaning utility 30 times, it reminded me that cleaning can only be done a few tims before ink is depleted.
When you said that you changed the cartridge and got nothing, it reminded me that one should remove the clear tape on the cartridge before installing the new cartridge, or else no print out will be seen.
If a new cartridge is installed and it still does not print out magenta, then the printer may require service at
Feb 02, 2011 | Canon MP610 Photo All-In-One Printer
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Cannon ink jet quit printing black
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel. # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right). # Continue doing this until it looks clean. # Then dab the cartridge on the towel to make sure the ink is flowing. # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier. 2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
79 people viewed this question
