Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Harddrive won't start - Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
    Brigadier General:
  • 10,406 Answers
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, at a significant discount.
Posted on Nov 04, 2010
6710b harddisk controller gone
have you replaced the harddrive?
will it let you start up in safe mode?
can you let me know what it says on screen when you try to start up please.
Jul 07, 2014 | HP Compaq Presario CQ60Z Notebook
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
What type of hardrive do i need for my packard bell istart 2369 desktop computer?
For one, I abhor Packard Bell, and the lack of support for it's users, of older computers.
If you don't support your computers, I say do not buy one from them.
(Oh, excuse me. For $$$$$$ they will)
Can't even find the specifications on the internet, (I do not own one), and Peckard Bell Support is of no help.
So let's do it another way.
What kind of cables connect to the Harddrive?
This will tell us if it is an IDE unit, or a SATA unit.
An IDE, (Also known as PATA), harddrive uses a flat ribbon cable, for it's data cable,
http://en.wikipedia.org/wiki/Parallel_ATA
Click on the photo all the way to the upper right. Shows a blue connector on a grayish flat cable.
The power cable for an IDE (PATA) harddrive, is a 4-pin standard Peripheral power cable. Shown here,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the harddrive shown in the photos, is an IDE harddrive.
If it is a SATA unit, it will use a SATA power cable.
Has 15 contact pins in the connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
The SATA power cable has an L connection on the inside, to match the L connection on the back of the harddrive.
Same with a SATA data cable, only it is shorter in width, and has 7 contact pins,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Also look at the label of the harddrive, and state what you see.
Is it a Seagate harddrive? What is the size? 250GB?
Smaller? Larger?
Once we find this info out, I can recommend harddrives.
Be aware that the Windows operating system was on that harddrive.
If you install a new harddrive, it won't have Windows on it.
You will need to obtain a genuine copy of Windows, and install it.
Post back in a Comment.
Regards,
joecoolvette
May 13, 2012 | Computers & Internet
Hp pavilion dv9000 blue lights on won`t boot stuck just cli
Sounds like the harddrive went bad.
Some people call it the click of death.
Put the laptop to your ear near the harddrive and you will hear the clicking coming from there.
Good news is that it's easy enough to change the harddrive.
Bad news is you lose all your data to this point.
I hope this helps and i'm sorry that happend to you.
Dec 24, 2008 | Acer Aspire 5315 Notebook
New hard drive
you got a problem there.
may be you can return it and get a 80GB harddrive. e-mail me fo rinstruction how to install update BIOS.
Sep 30, 2008 | Fujitsu LifeBook B2131 Notebook
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
