Question about Fuji FinePix S9100 Digital Camera
Aperture Settings Aperture will not adjust to any setting beyond F/8, e.g F/11 or F/16 in any mode.
This camera will go smaller than F/8 (as small as F/11) but only in manual mode.
Posted on Nov 03, 2009
Reread the operations manual. Camera is designed to produce aperture no smaller than F/8.
Posted on Jun 13, 2008
How do I adjust my flash mode on auto shooting mode?
I don't know the Leica camera, but the auto mode means the camera does take care of everything. The only thing you can do is choose the camera, not to use the flash, so it needs to measure and use a higher ISO. But if you want to adjust the flash, see what the camera did choose for shutter speed and aperture. Then put it in manual, choose the same and use your flash to the setting you want. Then adjust your settings. Can be the speed and or aperture, but also the flash to 1/2 1/4 or moe.
Jan 01, 2015 | Leica V-LUX 4 Digital Camera
Kodak Easyshare Z5010 takes black pictures only when in manual mode. I reset the settings but it still takes black pictures.
Check the settings that influence the exposure when your camera is in manual mode. There are three variables that you can adjust to change the exposure: ISO sensitivity, aperture (diaphragm) and shuttertime. When for instance the ISO is set to 100, aperture to F16 and shutterspeed to 1/1000 you will need a huge amount of light to get anything else than black pictures.
In a normal daylight situation you should get some results when using approximately the following settings: ISO100, F5.6 and 1/60 shutterspeed. Adjust these settings depending the light conditions and the results you get.
Nov 26, 2013 | Kodak Easyshare Z5010 14MP Digital Camera
The S and M modes on the dial..show black images when taking a pic; any idea why?
I'd say you're severely underexposing. The M mode is for manual exposure. This means you're responsible for setting the appropriate shutter speed and aperture. The aperture controls how much light passes through the lens, the shutter speed controls how long that light hits the sensor. The two of them have to be adjusted properly to suit the amount of light hitting the subject. If the lens doesn't admit enough light and/or the shutter is opened for too short an amount of time, not enough light gets to the sensor and you get a black image.
The S mode is for shutter priority. This lets you set the shutter speed and the camera automatically adjusts the lens aperture for correct exposure. However, the lens has a maximum aperture beyond which it cannot open. If the shutter speed is too fast, again not enough light gets through the lens and you get a black image.
Since you didn't specify the model of your Nikon camera, I can't tell you exactly how to adjust the shutter speed and aperture. If you can't find the procedure in your manual, please feel free to reply to this post, specifying the model.
Feb 24, 2011 | Nikon Cameras
Cannot adjust aperture or shutter speed in manual modes
Suggestion.... try to reset all settings to default. See what happens then.
Sep 08, 2009 | Canon Cameras
Aperture priority malfunction
davidsucklin,
You can use the film lens with the D80, but it it not react to the same settings as it did with the film body, the multiplier factor for the focal length is going to be different and it may be stopped down a bit. When you are shooting in aperture mode are you adjusting your shutter and ISO? The camera and the lens have to be communicating the same info to one another inorder for it to work. First set the camera back to auto mode the check the shot to see the settings (f-stop, shutter speed) test them with different ISO's to see what the camera thinks the settings should be, then go back to manual on the camera and lens and try the shutter priority mode with the aperture ring set at the 2.8 to see if it works then change to Aperture mode with the same settings that can take the picture. If it doesn't work keep in mind som of the older D lenses will drop some functionality (like aperture) in certain configurations. You can verfify compatibilty of your specific lens on Nikon's support site.
randy320sgi
Jan 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Adjusting the f stop
Lock the aperture in F 22. This will get rid of FEE. Now control the aperture settings from the body ( control infront of shutter release )
Aug 07, 2007 | Quantaray 28-90mm f/3.5-5.6 for Pentax
Aperture priority only in manual mode?
Yes. You pick the apature (the 3000 keeps it aorund the setting you pick) and then it automaticly adjusts the speed for you.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Aperture Priority Mode - an undocumented feature
In addition to the "quirks" of the Landscape and Aperture Priority Modes (neither mode works as documented!)..... The camera also behaves differently in full Manual Mode (it changes the settings, whether you want it to or not to compensate for available light)... At lower Zoom Levels, the camera will adjust the Shutter Speed Only, to try and compensate for available light... For example: with the Camera preset to F5.6 Aperture, and 1/48 sec. shutter speed, the camera will adjust the shutter speed between a range of 1/30 to 1/291 sec, to try and "auto expose" the shot for lower or higher light levels, even though you're in manual mode. At an Aperture Setting of 2.8 and 1/48 of a second, the number of internal steps in shutter speed the camera is willing to take, increases dramatially - for example: shutter speeds up to 1/600 of a second, even though you have the shutter set to 1/48 in manual mode. The camera WILL NOT attempt to adjust the Aperture to compensate for proper exposure in available light (OR WILL IT??).... It depends on your Zoom settings! It won't if your're near to full wide angle, but IT WILL if you are using the Zoom. Once you cross some unknown zoom threshold (it doesn't have to be at full zoom), then the camera begins to change both the Aperture and Shutter speed to compensate for available light, even though you are in "Full Manual", versus Auto Exposure Mode. In Manual Mode, (as in Aperture Priority Mode), the amount of change the camera is willing to make to your settings, appears to be related to a preset number of internal steps, with the number of steps dependent on both Aperture and Zoom Settings, before it gives an EV Warning for Over or Under Exposure conditions.... The type (shutter speed only for wide angle, shutter and aperture for zoom) and amount (number of internal "steps" it takes to increase/decrease shutter speed and increase or decrease aperture), is dependent on the amount of zoom you are using for the current shot.
Will a lenses without the A setting on the apeture ring work on a DS
They will - fully open in Av mode, and with any aperture in manual mode - after you allow the Ds through the custom settings menu to use aperture settings different then "A". To choose correct exposure with such a lens in manual mode you can use the AE-button - it stops down the aperture, reads the EV and sets the shutter speed according to the chosen aperture.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Fuji FinePix S9100 Digital Camera Logo
103 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
