Question about Parrot Par Ck3000 Evolution Ck3000 Handsfree Car
Cant turn the volume down on my parrot vm3.18 I am almost going deaf and get strange looks from people at traffic lights.
No volume on parrot ck3100
check the settings on your phone first. turn it up on your phone and then go to settings and move up the phone setting volume.
Aug 25, 2012 | Parrot Hands-Free Car Kit with LCD Display...
Iphone volume
Have you tried to remove the device from your iphones blue tooth list, and reset the connection?
Mar 15, 2012 | Parrot SA Parrot Evolution Bluetooth Car...
Sk4000 remote will not pair with headset, tried everything and checked with support. They said be sure and pair remote before pairing phone. Tried that and still nothing. if the remote is no good there is...
If you have verified that the battery is good in the unit, try this (from the folks at Parrot). The HCU is the main control unit.
1) Turn the HCU on
2) Clear the memory on the HCU by holding down the power button and accept call button (the two large buttons on the face of the HCU)
3) Wait until you hear the HCU make the request "please pair device"
4) Hold the volume up and the volume down keys on the remote for 15 seconds
5) Release the buttons on the remote.
It might be fixed now. Press the switch on the bottom of the remote to switch to radio and see.
Jun 09, 2011 | Parrot SA Parrot SK4000 Motorcycle...
Remote does not work on SK4000.
1) Turn the HCU on
Jun 04, 2011 | Parrot SA Parrot SK4000 Motorcycle...
I have a parrot ck3000, but i dont know how to erase the memory using only the steering wheel contols. i have tried to hold the call and answer buttons simultaneously but it does nothing, i have tried with...
You will need to plug in the original parrot control to do this. contact the supplier if you do not have it as they should have left it with you. Otherwise Parrot web site has a list of certified engineers.
Feb 19, 2011 | Parrot Par Ck3000 Evolution Ck3000...
Parrot keeps "calling" and counting time when I turn on car....bluetooth is connected to phone but I did not dial anyone!
You will need to update the software in this parrot, you can do this by downloading the parrot update manager from parrot web site, you will need a Laptop with Bluetooth to send the file to the parrot. If you cant do it the have a look at parrot.com and look for your nearest parrot engineer.
Jun 15, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
No intruction manual
hi
kindly download the user manual from the below link....
http://www.parrot.com/usa/support/userguides/parrotminikit
thank you
have a nice day
May 07, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot 3200 Ls doesn't cut out radio
problem is the 220 has an amplefier in boot the controls the radio, unless proper leads that connect there are used to interupt the radio when call happens it just some thing u have to put up with or buy the lead, try autoleads.com or look on parrot web site for the right leads
Mar 30, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot memory full
I had same problem too.
I have googled 3 days and found the solution from MULTICAN manual.
•Reset the hands-free kit:
Repeat the following sequence five times:
press the "Volume (-)" button and then the "Volume (+)".
And also F.Y.I.
•Enter the menu:
Press the following sequence twice: [SEEK up] button then the [SEEK down] button.
•Go forward through the menu: Press the "Volume (+)" button.
•Go backwards through the menu: Press the "Volume (-)" button.
•Select a menu option: Press the "Phone" button.
•Cancel a function: Long press of the "Phone" button.
Jan 18, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Motorola H700 Volume 'Up' Orientation
There is a way to change the orientation of the earpiece and volume buttons. Guest's comment was uncalled for. Suppose you are deaf in the ear that it comes set up for?
Nov 01, 2007 | Motorola Mobility H700 Wireless Headset
Parrot Par Ck3000 Evolution Ck3000 Handsfree Car Logo
102 people viewed this question
Top Parrot Cell Phones Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
