RCA HD52W59 shuts off by itself after it warms up. Allow it to stay off for awhile and it will come back on
  • cliffshort Jun 17, 2008
    found a loose connection at the sheilded ribbon cable from the power board...all fixed
  • 5,138 Answers
Poor connections on power supply board,leaky cap (C) 150- 2200uf 16volt.also check ribbon connectors coming from power supply board.
Posted on Jun 12, 2008
My rca HD52W59 shut itself off; i can power it on and i get a few seconds of audio, but no picture, then it shuts off. The green power light does not blink any sequences
This may be an indication that your H.O.T 'High Output Transistor' that is the main transistor that supplies the High Voltage to the 3 CRT's when the TV starts up. Just a thought.
May 24, 2012 | RCA HD52W59 HDTV Projection Television
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52W59 TV that will turn on and picture is fine for awhile, then it will fade to total black. Still has sound and does not power off. Nothing will show on screen, not even menu options....
Thats a deflection problem which is causing the CRTs to shut down during deflection loss. The deflection board will need replacement. You can get replacement deflection boards from www.tvrepairworld.com
Apr 23, 2011 | RCA HD52W59 HDTV Projection Television
Why does my tv turn off by itself
Bad capacitors on Deflection board cp114 cp120 cp150, they will be swollen.vented or puffed up on top
220uf 35v and 2200uf 16v use 25v
Apr 05, 2010 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 flyback transformer
your model uses the 270125 flyback if both wires are red. If one is red and the other black then you have the 259296 flyback.
Mar 21, 2010 | RCA HD52W59 HDTV Projection Television
Shut off by its self
replace the deflection board if it shuts off and stays off. If it shusts off but then comes back on by itself replace the small signal board. You can get replacements at www.tvrepairworld.com
Mar 20, 2010 | RCA HD52W59 HDTV Projection Television
Ok...I just replaced the .0087uf 2000vdc capacitor that had burned out and the TV came on and worked for about 30 minutes. Now it shuts off and turns itself back on 3 times then it stays off and you cant...
Check for any capacitors that havnt blown but may be very leaky and unable to retain charge, often found surrounding the blown components. Also check the power suply circuitry for any shorted components that may have faulted causing the capacitor to burn out. Good Luck.
Nov 25, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 color goes green then black screen
This set has flyback problems. you would need to check a few things to make sure. What about RP020 is this open? Check also RP231 and IP190. Check make sure all cables are seated properly too. For more info visit ctechnicians.com
Jan 03, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 problem
Sounds like you have a high voltage shutdown. A flyback or a crt is arching.
Dec 23, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 REAR PROJECTION
there should only be three colors.. can they be aligned?
Sep 16, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
