Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washing machine model lsq8243h
Won't spin
  • 413 Answers
The lid switch has failed.
To access it REMOVE POWER, lift the console by one of three ways. 1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward. 2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw. 3. insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The lid switch is attached to the cabinet.
Posted on Jun 13, 2008
How old is my Whirlpool washer LSQ8243H
Contact Whirlpool or call a local appliance repair shop; provide them with the model and serial numbers- they should be able to help.
Mar 16, 2015 | Whirlpool Washing Machines
Stops rinse cycle
needs a new timer
Feb 05, 2014 | Whirlpool LSQ8243H
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
Whirlpool lsq8243h
If it doesn't agitate but will spin it is probably the agitator cams.
Oct 07, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
LSQ8243H does not agitate and spin after water was filled, but pump the water out. What is wrong?
If you hear motor running, then probably bad coupler. Lately I have been seeing more and more bad transmissions in these.
Aug 28, 2010 | Whirlpool LSQ8243H
Washer won't spin
Broken drive coupling, bad clutch, striped drive block, timer skipping past paus in nutral drain.
lots of things can cause problem
Nov 22, 2009 | Whirlpool LSQ8243H
Agitator slipping
Replace the coupler. It is located between the motor and the transmission. I think it retails at about $8.00.
Apr 01, 2009 | Whirlpool LSQ8243H
Whirlpool Lsq8243h
unplug washer and lean washer back aganst wall,put something under frount of washer.So you can see under washer .Look and see if the belt are still on the pully or if there streached out (not tight) fix accordingly.
Jan 17, 2009 | Whirlpool LSQ8243H
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
